[MOAB-dev] Discussion on return type of MOAB routines
Jed Brown jed at jedbrown.org
Wed Jan 22 10:16:20 CST 2014
"Wu, Danqing" <wuda at mcs.anl.gov> writes:
> The object contains an enum type ErrorCode and std::string. The size
> of this object is fixed, like 16 bytes in my test. However,
> std::string is essential like a wrapped pointer implemented by
> STL.
Yes, do you really want your error handler to use dynamic memory allocation?
> Here I think the "size" Tim mentions is related to the length of the
> string, which will affect the performance of the copy constructor of
> std::string, when this object is returned by value from MOAB routines.
You could use a pointer so that there is no copy, but you have to
allocate the string somewhere.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140122/922f68ec/attachment.pgp>
