[MOAB-dev] Closing/opening moab instances
    Tim Tautges (ANL)
    tautges at mcs.anl.gov
    Mon Jan 20 14:58:29 CST 2014
On 01/20/2014 02:10 PM, Paul Wilson wrote:
> Hi Tim,
> On 01/20/2014 01:43 PM, Tim Tautges (ANL) wrote:
>> Hmm, then I'd add a ticket for MOAB that requests this entity set get populated appropriately. Are you sure this isn't
>> being handled properly outside CGM, on the MOAB side?
> I think it depends a little what you mean by handled properly - perhaps a slightly more detailed response where I try to
> be more careful with terminology.
> In a call to ReadCGM::load_file() there is a MOAB entity set available for correctly grouping the MOAB entities that are
> generated during that call. However, during ReadCGM::load_file(), there is a call to CubitCompat_import_solid_model()
> that loads a solid model into the CGM singleton instance. Thereafter, there is a call to
> GeometryQueryTool::ref_entity_list() for all the RefEntities of a given dimension.
> If the geometry is explicitly cleared/deleted before a call to ReadCGM::load_file(), then those calls to
> GeometryQueryTool::ref_entity_list() will only return the RefEntities that are associated with the most recent
> CubitCompat_import_solid_model(), and associate them correctly with the MOAB file entity set.
> If the geometry is NOT cleared/deleted before a call to ReadCGM::load_file(), then those calls to
> GeometryQueryTool::ref_entity_list() will return ALL the RefEntities that are associated with ALL PREVIOUS
> CubitCompat_import_solid_model(), and associate them ALL with the MOAB file entity set.
> I don't think it's a problem on the MOAB side, per se. I think it's a problem with the expected behavior of
> ReadCGM::load_file() over multiple subsequent calls. I don't think this behavior has been explicitly defined before and
> the kind of tests that Patrick was writing exposed this for the first time.
Ok, right.
First, I think it would be good to enable both behaviors (keep the model or delete it), because I can envision plausible
use cases for both (and, since we eventually want some of this code to be shared or move to MeshKit, obviously we'll
need it there).
Second, I guess if the model in CGM is not deleted, then either ReadCGM needs to keep a reference to it and filter out
those from subsequent reads, or we need a tag pointing from the MOAB entity sets to their CGM counterparts (sounds like
iRel/Lasso, no?).
- tim
> It is difficult to imagine a case where the user would want the current behavior. The most logical default behavior to
> me is to clear the solid model before each CubitCompat_import_solid_model(), and allow an option to prevent this.
> Does this make sense?
> Paul
>> - tim
>> On 01/18/2014 07:40 AM, Paul Wilson wrote:
>>> On Jan 17, 2014, at 20:48, "Tautges, Timothy J." <tautges at mcs.anl.gov <mailto:tautges at mcs.anl.gov>> wrote:
>>>> I think it should be optional too. Patrick, each separate read should be passing in an entity set anyway, so either
>>>> way you should be able to tell what resulted from a given read.
>>> This is only true if the geom gets cleared each time because ReadCGM calls import_solid_model w/o any notion of a set to
>>> hold it separate. ReadCGM then queries the geom for all RefEntities of a given dimension. Thus, even with a distinct
>>> entity set on the MOAB side, it will contain all the entities from prior reads if the geom doesn't get cleared.
>>> Paul
>>> Professor, Nuclear Engineering
>>> Faculty Director, Advanced Computing Infrastructure
>>> UW-Madison
>>> wilsonp at engr.wisc.edu <mailto:wilsonp at engr.wisc.edu>, 608.263.0807
>>> Sent from my iPhone
>>>> And, dated reply, but you can't create/destroy multiple cgm instances in the same session, due to the singletons and
>>>> some other things in cgm.
>>>> Tim
>>>> Sent via the Samsung GALAXY S®4, an AT&T 4G LTE smartphone
>>>> -------- Original message --------
>>>> From: Paul Wilson
>>>> Date:01/17/2014 4:33 PM (GMT-06:00)
>>>> To: "Grindeanu, Iulian R."
>>>> Cc: Patrick Shriwise ,"Tautges, Timothy J." ,moab-dev at mcs.anl.gov <mailto:moab-dev at mcs.anl.gov>
>>>> Subject: Re: [MOAB-dev] Closing/opening moab instances
>>>> Hi all
>>>> Actually, I don't think we should always delete_ geometry after ReadCGM. There is theoretically a DAGMC capability to
>>>> use the geometry for some ray-firing calls that would require the geometry to be loaded. (We need to add tests for
>>>> this.)
>>>> We could add options to ReadCGM:
>>>> • on/off delete on entering ReadCGM()
>>>> • on/off delete on exiting ReadCGM()
>>>> Paul
>>>> UW-Madison
>>>> Sent from my iPhone
>>>> > On Jan 17, 2014, at 16:15, "Grindeanu, Iulian R." <iulian at mcs.anl.gov <mailto:iulian at mcs.anl.gov>> wrote:
>>>> > I think we should call "delete_geometry" on cgm instance after read_cgm finishes its job.
>>>> > I cannot think of any instance in which we would want the entities persistent.
>>>> > maybe Rajeev has though issues when coregen-type calls are made in meshkit. I know that there multiple files
>>>> > are loaded; I assume that these files are sat/occ files, and are read as geometry, not converted to mesh by
>>>> ReadCGM. Tim or Rajeev could confirm if calling "delete_geometry" is a problem or not;
>>>> > Thanks,
>>>> > Iulian
>>>> > ________________________________________
>>>> > From:moab-dev-bounces at mcs.anl.gov <mailto:moab-dev-bounces at mcs.anl.gov> [moab-dev-bounces at mcs.anl.gov
>>>> <mailto:moab-dev-bounces at mcs.anl.gov>] on behalf of Patrick Shriwise [shriwise at wisc.edu <mailto:shriwise at wisc.edu>]
>>>> > Sent: Friday, January 17, 2014 4:02 PM
>>>> > To: Tautges, Timothy J.
>>>> > Cc:moab-dev at mcs.anl.gov <mailto:moab-dev at mcs.anl.gov>
>>>> >> On 01/14/2014 09:46 AM, Patrick Shriwise wrote:
>>>> >>> On 01/09/2014 12:43 PM, Tim Tautges (ANL) wrote:
>>>> >>> Either declare the Core instance in a local variable, e.g. as in the
>>>> >>> test/MBTest.cpp test (mb_vertex_coordinate_test function and the ones
>>>> >>> following), or use Interface::delete_mesh. I'd recommend the former,
>>>> >>> as that gives you a clean instance.
>>>> >>> - tim
>>>> >>>> On 01/09/2014 12:22 PM, Patrick Shriwise wrote:
>>>> >>>> Hi all,
>>>> >>>> Working on a set of tests in which I would like to read an ACIS file
>>>> >>>> independently in several different functions using
>>>> >>>> moab::Core::load_file. I believe that I am creating a new moab
>>>> >>>> instance in every function. However when I load the file
>>>> >>>> in a new function, the data from the original load seems to remain.
>>>> >>>> Any advice on how to load the file without having it
>>>> >>>> overlap between functions?
>>>> >>>> Cheers,
>>>> >>> I've setup my local moab instance calls just as in MBTest.cpp and
>>>> >>> mb_vertex_coordinate_test but am still having the same problem. When
>>>> >>> I load a simple cube geometry and check that it has the appropriate
>>>> >>> number of vertices it works the first time, but if I repeat the test
>>>> >>> in main it will find twice the number of vertices as expected upon a
>>>> >>> repeated test run. Any thoughts?
>>>> > Hey all,
>>>> > Got this problem figured out. When loading a file using
>>>> > ReadCGM::load_file , a CGM instance is created which is persistent (see
>>>> > InitCGMA.cpp lines 65-80). This means that unless the CGMA geometry is
>>>> > removed before leaving ReadCGM, it still exists when loading another
>>>> > file or the same file whether this occurs in the same MOAB instance or
>>>> > not. By adding to ReadCGM a line calling delete_geometry() from CGM at
>>>> > the end of ReadCGM::load_file it allows the CGMA data to be removed and
>>>> > leave the existing MOAB Entities in tact.
>>>> > This leads to a question: Is there ever a case in which we would want to
>>>> > re-access the CGMA geometry data from a file after transferring it to
>>>> > MOAB (loading a file twice, loading multiple files into CGMA then moving
>>>> > it to MOAB, etc. ) or should this be the default behavior for ReadCGM?
>>>> > For the current DAGMC workflow its is not necessary or problematic that
>>>> > the CGM instance is persistent. Since we have all the ACIS geometry in a
>>>> > single file loaded once it is not an issue, however in testing that
>>>> > involves multiple file loads even in separate MOAB instances containing
>>>> > the original geometry AND the new geometry.
>>>> > Which leads up to my real question, will adding a delete_geometry() call
>>>> > from CGM cause problems in everyone else's workflow? (This change does
>>>> > not break other tests.)
>>>> > Thanks ,
>>>> > Patrick
>>>> > Patrick C. Shriwise
>>>> > Research Assistant
>>>> > University of Wisconsin - Madison
>>>> > Engineering Research Building - Rm. 428
>>>> > 1500 Engineering Drive
>>>> > Madison, WI 53706
>>>> > (608) 446-8173
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
