[MOAB-dev] Closing/opening moab instances
Paul Wilson wilsonp at engr.wisc.edu
Fri Jan 17 16:33:07 CST 2014
Hi all
Actually, I don't think we should always delete_ geometry after ReadCGM.  There is theoretically a DAGMC capability to use the geometry for some ray-firing calls that would require the geometry to be loaded. (We need to add tests for this.)
We could add options to ReadCGM:
• on/off delete on entering ReadCGM()
• on/off delete on exiting ReadCGM()
Paul
Professor, Nuclear Engineering
Faculty Director, Advanced Computing Infrastructure
UW-Madison
wilsonp at engr.wisc.edu, 608.263.0807
Sent from my iPhone
> On Jan 17, 2014, at 16:15, "Grindeanu, Iulian R." <iulian at mcs.anl.gov> wrote:
> I think we should call "delete_geometry" on cgm instance after read_cgm finishes its job.
> I cannot think of any instance in which we would want the entities persistent.
> maybe Rajeev has though issues when coregen-type calls are made in meshkit. I know that there multiple files
> are loaded; I assume that these files are sat/occ files, and are read as geometry, not converted to mesh by ReadCGM. Tim or Rajeev could confirm if calling "delete_geometry" is a problem or not;
> Thanks,
> Iulian
> From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf of Patrick Shriwise [shriwise at wisc.edu]
> Sent: Friday, January 17, 2014 4:02 PM
> To: Tautges, Timothy J.
> Cc: moab-dev at mcs.anl.gov
> Subject: Re: [MOAB-dev] Closing/opening moab instances
>> On 01/14/2014 09:46 AM, Patrick Shriwise wrote:
>>> On 01/09/2014 12:43 PM, Tim Tautges (ANL) wrote:
>>> Either declare the Core instance in a local variable, e.g. as in the
>>> test/MBTest.cpp test (mb_vertex_coordinate_test function and the ones
>>> following), or use Interface::delete_mesh.  I'd recommend the former,
>>> as that gives you a clean instance.
>>> - tim
>>>> On 01/09/2014 12:22 PM, Patrick Shriwise wrote:
>>>> Hi all,
>>>> Working on a set of tests in which I would like to read an ACIS file
>>>> independently in several different functions using
>>>> moab::Core::load_file. I believe that I am creating a new moab
>>>> instance in every function. However when I load the file
>>>> in a new function, the data from the original load seems to remain.
>>>> Any advice on how to load the file without having it
>>>> overlap between functions?
>>>> Cheers,
>>> I've setup my local moab instance calls just as in MBTest.cpp and
>>> mb_vertex_coordinate_test but am still having the same problem. When
>>> I load a simple cube geometry and check that it has the appropriate
>>> number of vertices it works the first time, but if I repeat the test
>>> in main it will find twice the number of vertices as expected upon a
>>> repeated test run. Any thoughts?
> Hey all,
>  Got this problem figured out. When loading a file using
> ReadCGM::load_file , a CGM instance is created which is persistent (see
> InitCGMA.cpp lines 65-80). This means that unless the CGMA geometry is
> removed before leaving ReadCGM, it still exists when loading another
> file or the same file whether this occurs in the same MOAB instance or
> not. By adding to ReadCGM a line calling delete_geometry() from CGM at
> the end of ReadCGM::load_file it allows the CGMA data to be removed and
> leave the existing MOAB Entities in tact.
> This leads to a question: Is there ever a case in which we would want to
> re-access the CGMA geometry data from a file after transferring it to
> MOAB (loading a file twice, loading multiple files into CGMA then moving
> it to MOAB, etc. ) or should this be the default behavior for ReadCGM?
> For the current DAGMC workflow its is not necessary or problematic that
> the CGM instance is persistent. Since we have all the ACIS geometry in a
> single file loaded once it is not an issue, however in testing that
> involves multiple file loads even in separate MOAB instances containing
> the original geometry AND the new geometry.
> Which leads up to my real question, will adding a delete_geometry() call
> from CGM cause problems in everyone else's workflow? (This change does
> not break other tests.)
> Thanks ,
> Patrick
> Patrick C. Shriwise
> Research Assistant
> University of Wisconsin - Madison
> Engineering Research Building - Rm. 428
> 1500 Engineering Drive
> Madison, WI 53706
> (608) 446-8173
