[MOAB-dev] Closing/opening moab instances
    Patrick Shriwise
    shriwise at wisc.edu
    Tue Jan 14 09:46:59 CST 2014
On 01/09/2014 12:43 PM, Tim Tautges (ANL) wrote:
> Either declare the Core instance in a local variable, e.g. as in the
> test/MBTest.cpp test (mb_vertex_coordinate_test function and the ones
> following), or use Interface::delete_mesh.  I'd recommend the former,
> as that gives you a clean instance.
> - tim
> On 01/09/2014 12:22 PM, Patrick Shriwise wrote:
>> Hi all,
>> Working on a set of tests in which I would like to read an ACIS file
>> independently in several different functions using
>> moab::Core::load_file. I believe that I am creating a new moab
>> instance in every function. However when I load the file
>> in a new function, the data from the original load seems to remain.
>> Any advice on how to load the file without having it
>> overlap between functions?
>> Cheers,
> I've setup my local moab instance calls just as in MBTest.cpp and
> mb_vertex_coordinate_test but am still having the same problem. When I
> load a simple cube geometry and check that it has the appropriate
> number of vertices it works the first time, but if I repeat the test
> in main it will find twice the number of vertices as expected upon a
> repeated test run. Any thoughts?
Patrick C. Shriwise
Research Assistant
University of Wisconsin - Madison
Engineering Research Building - Rm. 428
1500 Engineering Drive
Madison, WI 53706
(608) 446-8173
