[MOAB-dev] Closing/opening moab instances
Patrick Shriwise
shriwise at wisc.edu
Thu Jan 9 12:22:51 CST 2014
Hi all,
Working on a set of tests in which I would like to read an ACIS file
independently in several different functions using
moab::Core::load_file. I believe that I am creating a new moab instance
in every function. However when I load the file in a new function, the
data from the original load seems to remain. Any advice on how to load
the file without having it overlap between functions?
Cheers,
Patrick C. Shriwise
Research Assistant
University of Wisconsin - Madison
Engineering Research Building - Rm. 428
1500 Engineering Drive
Madison, WI 53706
(608) 446-8173
