[MOAB-dev] commit/MOAB: danwu: Error handling enhancement for MOAB (initial submission), with src/moab/ErrorHandler.hpp and src/ErrorHandler.cpp created. Like moab::Range class, the new interface for error handling can be consumed by MOAB and user applications later.
commits-noreply at bitbucket.org
Wed Jan 8 14:30:27 CST 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/ca3f5dca05a2/
Changeset: ca3f5dca05a2
Branch: error_handling_enhancement
User: danwu
Date: 2014-01-08 21:27:01
Summary: Error handling enhancement for MOAB (initial submission), with src/moab/ErrorHandler.hpp and src/ErrorHandler.cpp created. Like moab::Range class, the new interface for error handling can be consumed by MOAB and user applications later.
Affected #: 4 files
diff --git a/src/ErrorHandler.cpp b/src/ErrorHandler.cpp
new file mode 100644
index 0000000..18c7150
--- /dev/null
+++ b/src/ErrorHandler.cpp
@@ -0,0 +1,28 @@
+#include "moab/ErrorHandler.hpp"
+#include <iostream>
+using namespace std;
+namespace moab {
+void MBTraceBackErrorHandler(int line, const char* func, const char* file, const char* err_msg, ErrorType err_type)
+ // Print the error message
+ if (MB_ERROR_TYPE_NEW == err_type) {
+ if (err_msg)
+ cout << "[Error message]: " << err_msg << endl;
+ // Print a line of stack trace
+ cout << func << "() at line " << line << ", in file " << file << endl;
+ErrorInfo MBError(int line, const char* func, const char* file, const ErrorInfo& err_info, ErrorType err_type)
+ MBTraceBackErrorHandler(line, func, file, err_info.get_error_msg(), err_type);
+ return err_info;
+} // namespace moab
diff --git a/src/Makefile.am b/src/Makefile.am
index 5772d12..0ec5d2c 100644
--- a/src/Makefile.am
+++ b/src/Makefile.am
@@ -56,6 +56,7 @@ libMOAB_la_SOURCES = \
ElementSequence.hpp \
EntitySequence.cpp \
EntitySequence.hpp \
+ ErrorHandler.cpp \
Factory.cpp \
FBEngine.cpp \
FileOptions.cpp \
@@ -161,6 +162,7 @@ nobase_libMOAB_la_include_HEADERS = \
moab/HomXform.hpp \
moab/EntityType.hpp \
moab/EntityHandle.hpp \
+ moab/ErrorHandler.hpp \
moab/FBEngine.hpp \
moab/FileOptions.hpp \
moab/FindPtFuncs.h \
diff --git a/src/moab/ErrorHandler.hpp b/src/moab/ErrorHandler.hpp
index 0000000..60ef0fd
--- /dev/null
+++ b/src/moab/ErrorHandler.hpp
@@ -0,0 +1,141 @@
+#ifndef MOAB_ERROR_HANDLER_HPP
+#define MOAB_ERROR_HANDLER_HPP
+#include "moab/Types.hpp"
+#include <sstream>
+namespace moab {
+enum ErrorType { MB_ERROR_TYPE_NEW = 0, MB_ERROR_TYPE_EXISTING = 1 };
+class ErrorInfo {
+ ErrorCode mErrorCode;
+ std::ostringstream mErrorMsg;
+public:
+ ErrorInfo(ErrorCode err_code = MB_FAILURE, const char* err_msg = "") : mErrorCode(err_code)
+ if (err_msg)
+ mErrorMsg << err_msg;
+ ErrorInfo(const ErrorInfo& err_info)
+ : mErrorCode(err_info.mErrorCode)
+ mErrorMsg << err_info.mErrorMsg.str();
+ void set_error_code(ErrorCode err_code)
+ mErrorCode = err_code;
+ ErrorCode get_error_code() const
+ return mErrorCode;
+ void set_error_msg(const char* err_msg)
+ if (err_msg) {
+ mErrorMsg.str("");
+ const char* get_error_msg() const
+ return mErrorMsg.str().c_str();
+ const ErrorInfo& operator=(const ErrorInfo& err_info)
+ if (this != &err_info) {
+ mErrorCode = err_info.mErrorCode;
+ return *this;
+ // Use C++ string stream to build up an error message
+ template<typename T>
+ ErrorInfo& operator<<(T input)
+ mErrorMsg << input;
+ return *this;
+ // A conversion operator for converting ErrorInfo to ErrorCode
+ operator ErrorCode() const
+// Errors are handled through routine MBError()
+ErrorInfo MBError(int line, const char* func, const char* file, const ErrorInfo& err_info, ErrorType err_type);
+#define ERROR_INFO_SUCCESS ErrorInfo(MB_SUCCESS)
+#define SET_ERR(err_info) \
+ return MBError(__LINE__, __func__, __FILE__, err_info, MB_ERROR_TYPE_NEW)
+#define SET_ERR1(err_code, err_msg) \
+ return MBError(__LINE__, __func__, __FILE__, ErrorInfo(err_code, err_msg), MB_ERROR_TYPE_NEW)
+#define CHK_ERR(err_info) \
+ do { \
+ if (MB_SUCCESS != err_info) \
+ return MBError(__LINE__, __func__, __FILE__, err_info, MB_ERROR_TYPE_EXISTING); \
+ } while (false)
+#define CHK_ERR1(err_info, err_msg_to_set) \
+ do { \
+ if (MB_SUCCESS != err_info) { \
+ err_info.set_error_msg(err_msg_to_set); \
+ SET_ERR(err_info); \
+ } while (false)
+#define CHK_ERR2(err_info, err_code_to_set, err_msg_to_set) \
+ do { \
+ err_info.set_error_code(err_code_to_set); \
+ } while (false)
+#define CHK_EQL(err_info, exp_err_code) \
+ do { \
+ if (exp_err_code != err_info) { \
+ err_info.set_error_code(MB_FAILURE); \
+ err_info.set_error_msg("Returned error code is not expected."); \
+ } while (false)
+#define CHK_EQL1(err_info, exp_err_code, err_msg_to_set) \
+ do { \
+ err_info.set_error_code(MB_UNEXPECTED_ERROR_CODE); \
+ } while (false)
+#define CHK_EQL2(err_info, exp_err_code, err_code_to_set, err_msg_to_set) \
+ do { \
+ } while (false)
+#endif
diff --git a/src/moab/Interface.hpp b/src/moab/Interface.hpp
index 09f4219..8ffe2a3 100644
--- a/src/moab/Interface.hpp
+++ b/src/moab/Interface.hpp
@@ -43,6 +43,7 @@
#include "moab/Forward.hpp"
#include "moab/Range.hpp"
#include "moab/Compiler.hpp"
// include files
#include <string>
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
