[MOAB-dev] commit/MOAB: iulian07: lloyd smoother test depends on	hdf5
    commits-noreply at bitbucket.org
    Wed Jan  8 08:41:37 CST 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/1e70f4cd8985/
Changeset:   1e70f4cd8985
Branch:      master
User:        iulian07
Date:        2014-01-08 15:40:34
Summary:     lloyd smoother test depends on hdf5
do this test only if built with HDF5
Affected #:  1 file
diff --git a/test/Makefile.am b/test/Makefile.am
index 0aabcce..631e126 100644
--- a/test/Makefile.am
+++ b/test/Makefile.am
@@ -48,15 +48,16 @@ TESTS = range_test \
 	coords_connect_iterate \
 	elem_eval_test \
 	spatial_locator_test \
-	test_boundbox \
-	lloyd_smoother_test
+	test_boundbox
 if HDF5_FILE
   TESTS += mbfacet_test \
         gttool_test \
         cropvol_test \
         mergemesh_test \
-        mbground_test
+        mbground_test \
+        lloyd_smoother_test
 endif
 #                 merge_test \         # input files no longer exist?
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
