[MOAB-dev] Creating geometry from sets of triangles
Paul Wilson
wilsonp at engr.wisc.edu
Tue Jan 7 21:44:13 CST 2014
On 01/07/2014 10:02 AM, Tim Tautges (ANL) wrote:
> On 01/06/2014 05:04 PM, Paul Wilson wrote:
>> Hello MOAB team,
>> I'm looking to write a new reader for MOAB to read wavefront (obj)
>> files. These are sets of triangles - I think very
>> similar to STL files - that enclose volumes. (STL may be another
>> option here actually.) In the primary geometry of
>> interest, there are nested regions of space, each enclosed by a set
>> of triangles. I'd like to generate a model a la
>> DAGMC that correctly excludes the nested volumes from its parent, etc.
> Do these wavefront files have information on the grouping of the
> triangles? If so, it should be relatively easy to separate and nest
> the groups, since presumably the bounding boxes would also be nested.
Yes, the format in question has the triangles arranged in groups.
>> It seems that something like this perhaps exists already, either in
>> MOAB, or CGM, or Cubit, and I wonder what advice the
>> MOAB team has for accomplishing this. I've thought about some
>> algorithmic notions to do this, but didn't want to get
>> too far down the implementation without checking here first.
> I'm not sure it does completely. If you can group the triangles, you
> could build that into a volume-surface topological structure, but that
> would give you almost the same thing as evaluating bounding boxes of
> the collections directly.
> I recently added a BoundBox class to MOAB that provides a bounding box
> for entity sets or ranges, that would probably help. I could also
> maybe see adding > and < operators to that class to evaluate nesting,
> though relying on floating point comparisons like that can be kind of
> dicey if they're close.
That does sound useful. I'll plan to develop something based on this.
Paul
Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
Faculty Director, Advanced Computing Infrastructure
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140107/42aa5c13/attachment.bin>
