[MOAB-dev] commit/MOAB: tautges: Moving TupleList class from parallel to non-parallel location, since it's now used in SpatialLocator serial version too.
commits-noreply at bitbucket.org
Tue Jan 7 14:58:09 CST 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/1e5572f59906/
Changeset: 1e5572f59906
Branch: master
User: tautges
Date: 2014-01-07 21:58:00
Summary: Moving TupleList class from parallel to non-parallel location, since it's now used in SpatialLocator serial version too.
Mostly passes make check serial/parallel (though a few other problems appear there...)
Affected #: 6 files
diff --git a/src/Makefile.am b/src/Makefile.am
index 0d474b0..0a05543 100644
--- a/src/Makefile.am
+++ b/src/Makefile.am
@@ -124,6 +124,7 @@ libMOAB_la_SOURCES = \
TagInfo.cpp \
TagInfo.hpp \
Tree.cpp \
+ TupleList.cpp \
Types.cpp \
TypeSequenceManager.cpp \
TypeSequenceManager.hpp \
@@ -195,6 +196,7 @@ nobase_libMOAB_la_include_HEADERS = \
moab/SpectralMeshTool.hpp \
moab/Tree.hpp \
moab/TreeStats.hpp \
+ moab/TupleList.hpp \
moab/Types.hpp \
moab/UnknownInterface.hpp \
moab/Util.hpp \
diff --git a/src/TupleList.cpp b/src/TupleList.cpp
new file mode 100644
index 0000000..bf08946
--- /dev/null
+++ b/src/TupleList.cpp
@@ -0,0 +1,860 @@
+#include <string.h>
+#include <limits.h>
+#include <stdio.h>
+#include <stdlib.h>
+#include <stdarg.h>
+#include <iostream>
+#include "moab/TupleList.hpp"
+namespace moab {
+void fail(const char *fmt, ...)
+ va_list ap;
+ va_start(ap, fmt);
+ vfprintf(stderr, fmt, ap);
+ va_end(ap);
+ exit(1);
+TupleList::buffer::buffer(size_t sz)
+ ptr = NULL;
+ buffSize = 0;
+ this->buffer_init_(sz, __FILE__);
+TupleList::buffer::buffer()
+ buffSize = 0;
+ ptr = NULL;
+void TupleList::buffer::buffer_init_(size_t sizeIn, const char *file)
+ this->buffSize = sizeIn;
+ void *res = malloc(this->buffSize);
+ if (!res && buffSize > 0)
+ fail("%s: allocation of %d bytes failed\n", file, (int) buffSize);
+ ptr = (char*) res;
+void TupleList::buffer::buffer_reserve_(size_t min, const char *file)
+ if (this->buffSize < min)
+ size_t newSize = this->buffSize;
+ newSize += newSize / 2 + 1;
+ if (newSize < min)
+ newSize = min;
+ void *res = realloc(ptr, newSize);
+ if (!res && newSize > 0)
+ fail("%s: allocation of %d bytes failed\n", file, (int) this->buffSize);
+ this->buffSize = newSize;
+void TupleList::buffer::reset()
+ free(ptr);
+ ptr = NULL;
+ buffSize = 0;
+TupleList::TupleList(uint p_mi, uint p_ml, uint p_mul, uint p_mr, uint p_max)
+ vi = NULL;
+ vl = NULL;
+ vul = NULL;
+ vr = NULL;
+ initialize(p_mi, p_ml, p_mul, p_mr, p_max);
+TupleList::TupleList()
+ vi = NULL;
+ vl = NULL;
+ vul = NULL;
+ vr = NULL;
+ disableWriteAccess();
+// Allocates space for the tuple list in memory according to parameters
+void TupleList::initialize(uint p_mi, uint p_ml, uint p_mul, uint p_mr,
+ uint p_max)
+ this->n = 0;
+ this->max = p_max;
+ this->mi = p_mi;
+ this->ml = p_ml;
+ this->mul = p_mul;
+ this->mr = p_mr;
+ size_t sz;
+ if (max * mi > 0)
+ sz = max * mi * sizeof(sint);
+ void *resi = malloc(sz);
+ if (!resi && max * mi > 0)
+ fail("%s: allocation of %d bytes failed\n", __FILE__, (int) sz);
+ vi = (sint*) resi;
+ else
+ vi = NULL;
+ if (max * ml > 0)
+ sz = max * ml * sizeof(slong);
+ void *resl = malloc(sz);
+ if (!resl && max * ml > 0)
+ vl = (slong*) resl;
+ else
+ vl = NULL;
+ if (max * mul > 0)
+ sz = max * mul * sizeof(ulong);
+ void *resu = malloc(sz);
+ if (!resu && max * mul > 0)
+ vul = (ulong*) resu;
+ else
+ vul = NULL;
+ if (max * mr > 0)
+ sz = max * mr * sizeof(realType);
+ void *resr = malloc(sz);
+ if (!resr && max * ml > 0)
+ vr = (realType*) resr;
+ else
+ vr = NULL;
+ //Begin with write access disabled
+ this->disableWriteAccess();
+ //Set read variables
+ vi_rd = vi;
+ vl_rd = vl;
+ vul_rd = vul;
+ vr_rd = vr;
+// Resizes a tuplelist to the given uint max
+ErrorCode TupleList::resize(uint maxIn)
+ this->max = maxIn;
+ size_t sz;
+ if (vi || (max * mi > 0))
+ void *resi = realloc(vi, sz);
+ return moab::MB_MEMORY_ALLOCATION_FAILED;
+ if (vl || (max * ml > 0))
+ void *resl = realloc(vl, sz);
+ if (vul || (max * mul > 0))
+ void *resu = realloc(vul, sz);
+ if (vr || (max * mr > 0))
+ void *resr = realloc(vr, sz);
+ if (!resr && max * mr > 0)
+ vi_rd = vi;
+ vl_rd = vl;
+ vul_rd = vul;
+ vr_rd = vr;
+ //Set the write variables if necessary
+ if (writeEnabled)
+ vi_wr = vi;
+ vl_wr = vl;
+ vul_wr = vul;
+ vr_wr = vr;
+ return moab::MB_SUCCESS;
+// Frees the memory used by the tuplelist
+void TupleList::reset()
+ //free up the pointers
+ free(vi);
+ free(vl);
+ free(vul);
+ free(vr);
+ //Set them all to null
+ vr = NULL;
+ vi = NULL;
+ vul = NULL;
+ vl = NULL;
+ //Set the read and write pointers to null
+ vi_rd = NULL;
+ vl_rd = NULL;
+ vul_rd = NULL;
+ vr_rd = NULL;
+// Increments n; if n>max, increase the size of the tuplelist
+void TupleList::reserve()
+ n++;
+ while (n > max)
+ resize((max ? max + max / 2 + 1 : 2));
+ last_sorted = -1;
+// Given the value and the position in the field, finds the index of the tuple
+// to which the value belongs
+int TupleList::find(unsigned int key_num, sint value)
+ ulong uvalue = (ulong) value;
+ if (!(key_num > mi))
+ // Binary search: only if the tuple_list is sorted
+ if (last_sorted == (int) key_num)
+ int lb = 0, ub = n, index; // lb=lower bound, ub=upper bound, index=mid
+ for (; lb <= ub;)
+ index = (lb + ub) / 2;
+ if (vi[index * mi + key_num] == (long) uvalue)
+ return index;
+ else if (vi[index * mi + key_num] > (long) uvalue)
+ ub = index - 1;
+ else if (vi[index * mi + key_num] < (long) uvalue)
+ lb = index + 1;
+ else
+ // Sequential search: if tuple_list is not sorted
+ for (long index = 0; index < n; index++)
+ return index;
+ return -1; // If the value wasn't present or an invalid key was given
+int TupleList::find(unsigned int key_num, slong value)
+ if (!(key_num > ml))
+ if (last_sorted - mi == key_num)
+ for (; lb <= ub;)
+ if (vl[index * ml + key_num] == (long) uvalue)
+ return index;
+ else if (vl[index * ml + key_num] > (long) uvalue)
+ ub = index - 1;
+ else if (vl[index * ml + key_num] < (long) uvalue)
+ lb = index + 1;
+ else
+ for (uint index = 0; index < n; index++)
+ return index;
+int TupleList::find(unsigned int key_num, ulong value)
+ if (!(key_num > mul))
+ if (last_sorted - mi - ml == key_num)
+ int lb = 0, ub = n - 1, index; // lb=lower bound, ub=upper bound, index=mid
+ for (; lb <= ub;)
+ if (vul[index * mul + key_num] == value)
+ return index;
+ else if (vul[index * mul + key_num] > value)
+ ub = index - 1;
+ else if (vul[index * mul + key_num] < value)
+ lb = index + 1;
+ else
+ return index;
+int TupleList::find(unsigned int key_num, realType value)
+ if (!key_num > mr)
+ // Sequential search: TupleList cannot be sorted by reals
+ if (vr[index * mr + key_num] == value)
+ return index;
+sint TupleList::get_sint(unsigned int index, unsigned int m)
+ if (mi > m && n > index)
+ return vi[index * mi + m];
+ return 0;
+slong TupleList::get_int(unsigned int index, unsigned int m)
+ if (ml > m && n > index)
+ return vl[index * ml + m];
+ return 0;
+ulong TupleList::get_ulong(unsigned int index, unsigned int m)
+ if (mul > m && n > index)
+ return vul[index * mul + m];
+ return 0;
+realType TupleList::get_double(unsigned int index, unsigned int m)
+ if (mr > m && n > index)
+ return vr[index * mr + m];
+ return 0;
+ErrorCode TupleList::get(unsigned int index, const sint *&sp, const slong *&ip,
+ const ulong *&lp, const realType *&dp)
+ if (index <= n)
+ if (mi)
+ *&sp = &vi[index * mi];
+ else
+ *&sp = NULL;
+ if (ml)
+ *&ip = &vl[index * ml];
+ else
+ *&ip = NULL;
+ if (mul)
+ *&lp = &vul[index * mul];
+ else
+ *&lp = NULL;
+ if (mr)
+ *&dp = &vr[index * mr];
+ else
+ *&dp = NULL;
+ return MB_SUCCESS;
+ return MB_FAILURE;
+unsigned int TupleList::push_back(sint *sp, slong *ip, ulong *lp, realType *dp)
+ reserve();
+ if (mi)
+ memcpy(&vi[mi * (n - 1)], sp, mi * sizeof(sint));
+ if (ml)
+ memcpy(&vl[ml * (n - 1)], ip, ml * sizeof(long));
+ if (mul)
+ memcpy(&vul[mul * (n - 1)], lp, mul * sizeof(ulong));
+ if (mr)
+ memcpy(&vr[mr * (n - 1)], dp, mr * sizeof(realType));
+ last_sorted = -1;
+ return n - 1;
+void TupleList::enableWriteAccess()
+ writeEnabled = true;
+ last_sorted = -1;
+ vi_wr = vi;
+ vl_wr = vl;
+ vul_wr = vul;
+ vr_wr = vr;
+void TupleList::disableWriteAccess()
+ writeEnabled = false;
+ vi_wr = NULL;
+ vl_wr = NULL;
+ vul_wr = NULL;
+ vr_wr = NULL;
+void TupleList::getTupleSize(uint &mi_out, uint &ml_out, uint &mul_out,
+ uint &mr_out) const
+ mi_out = mi;
+ ml_out = ml;
+ mul_out = mul;
+ mr_out = mr;
+uint TupleList::inc_n()
+ //Check for direct write access
+ if (!writeEnabled)
+ enableWriteAccess();
+ n++;
+ return n;
+void TupleList::set_n(uint n_in)
+ //Check for direct write access;
+ n = n_in;
+void TupleList::print(const char *name) const
+ std::cout << "Printing Tuple " << name << "===================" << std::endl;
+ unsigned long i = 0, l = 0, ul = 0, r = 0;
+ for (uint k = 0; k < n; k++)
+ for (uint j = 0; j < mi; j++)
+ std::cout << vi[i++] << " | ";
+ for (uint j = 0; j < ml; j++)
+ std::cout << vl[l++] << " | ";
+ for (uint j = 0; j < mul; j++)
+ std::cout << vul[ul++] << " | ";
+ for (uint j = 0; j < mr; j++)
+ std::cout << vr[r++] << " | ";
+ std::cout << std::endl;
+ std::cout << "=======================================" << std::endl
+ << std::endl;
+void TupleList::permute(uint *perm, void *work)
+ const unsigned int_size = mi * sizeof(sint), long_size = ml * sizeof(slong),
+ ulong_size = mul * sizeof(ulong), real_size = mr * sizeof(realType);
+ if (mi)
+ uint *p = perm, *pe = p + n;
+ char *sorted = (char *) work;
+ while (p != pe)
+ memcpy((void *) sorted, &vi[mi * (*p++)], int_size), sorted += int_size;
+ memcpy(vi, work, int_size * n);
+ if (ml)
+ while (p != pe)
+ memcpy((void *) sorted, &vl[ml * (*p++)], long_size), sorted += long_size;
+ memcpy(vl, work, long_size * n);
+ if (mul)
+ while (p != pe)
+ memcpy((void *) sorted, &vul[mul * (*p++)], ulong_size), sorted +=
+ ulong_size;
+ memcpy(vul, work, ulong_size * n);
+ if (mr)
+ while (p != pe)
+ memcpy((void *) sorted, &vr[mr * (*p++)], real_size), sorted += real_size;
+ memcpy(vr, work, real_size * n);
+# define umax_2(a, b) (((a)>(b)) ? (a):(b))
+ErrorCode TupleList::sort(uint key, TupleList::buffer *buf)
+ const unsigned int_size = mi * sizeof(sint);
+ const unsigned long_size = ml * sizeof(slong);
+ const unsigned ulong_size = mul * sizeof(ulong);
+ const unsigned real_size = mr * sizeof(realType);
+ const unsigned width = umax_2(umax_2(int_size,long_size),
+ umax_2(ulong_size,real_size));
+ const unsigned data_size =
+ key >= mi ? sizeof(SortData<long> ) : sizeof(SortData<uint> );
+ uint work_min = n * umax_2(2*data_size,sizeof(sint)+width);
+ uint *work;
+ buf->buffer_reserve(work_min);
+ work = (uint *) buf->ptr;
+ if (key < mi)
+ index_sort((uint *) &vi[key], n, mi, work, (SortData<uint>*) work);
+ else if (key < mi + ml)
+ index_sort((long*) &vl[key - mi], n, ml, work, (SortData<long>*) work);
+ else if (key < mi + ml + mul)
+ index_sort((ulong*) &vul[key - mi - ml], n, mul, work,
+ (SortData<ulong>*) work);
+ else
+ return MB_NOT_IMPLEMENTED;
+ permute(work, work + n);
+ last_sorted = key;
+#undef umax_2
+#define DIGIT_BITS 8
+#define DIGIT_VALUES (1<<DIGIT_BITS)
+#define DIGIT_MASK ((Value)(DIGIT_VALUES-1))
+#define CEILDIV(a,b) (((a)+(b)-1)/(b))
+#define DIGITS CEILDIV(CHAR_BIT*sizeof(Value),DIGIT_BITS)
+#define VALUE_BITS (DIGIT_BITS*DIGITS)
+#define COUNT_SIZE (DIGITS*DIGIT_VALUES)
+/* used to unroll a tiny loop: */
+#define COUNT_DIGIT_01(n,i) \
+ if(n>i) count[i][val&DIGIT_MASK]++, val>>=DIGIT_BITS
+#define COUNT_DIGIT_02(n,i) COUNT_DIGIT_01(n,i); COUNT_DIGIT_01(n,i+ 1)
+#define COUNT_DIGIT_04(n,i) COUNT_DIGIT_02(n,i); COUNT_DIGIT_02(n,i+ 2)
+#define COUNT_DIGIT_08(n,i) COUNT_DIGIT_04(n,i); COUNT_DIGIT_04(n,i+ 4)
+#define COUNT_DIGIT_16(n,i) COUNT_DIGIT_08(n,i); COUNT_DIGIT_08(n,i+ 8)
+#define COUNT_DIGIT_32(n,i) COUNT_DIGIT_16(n,i); COUNT_DIGIT_16(n,i+16)
+#define COUNT_DIGIT_64(n,i) COUNT_DIGIT_32(n,i); COUNT_DIGIT_32(n,i+32)
+template<class Value>
+Value TupleList::radix_count(const Value *A, const Value *end, Index stride,
+ Index count[DIGITS][DIGIT_VALUES])
+ Value bitorkey = 0;
+ memset(count, 0, COUNT_SIZE * sizeof(Index));
+ do
+ Value val = *A;
+ bitorkey |= val;
+ COUNT_DIGIT_64(DIGITS, 0);
+ // above macro expands to:
+ //if(DIGITS> 0) count[ 0][val&DIGIT_MASK]++, val>>=DIGIT_BITS;
+ //if(DIGITS> 1) count[ 1][val&DIGIT_MASK]++, val>>=DIGIT_BITS;
+ //if(DIGITS>63) count[63][val&DIGIT_MASK]++, val>>=DIGIT_BITS;
+ } while (A += stride, A != end);
+ return bitorkey;
+#undef COUNT_DIGIT_01
+#undef COUNT_DIGIT_02
+#undef COUNT_DIGIT_04
+#undef COUNT_DIGIT_08
+#undef COUNT_DIGIT_16
+#undef COUNT_DIGIT_32
+#undef COUNT_DIGIT_64
+void TupleList::radix_offsets(Index *c)
+ Index sum = 0, t, *ce = c + DIGIT_VALUES;
+ do
+ t = *c, *c++ = sum, sum += t;
+ while (c != ce);
+unsigned TupleList::radix_zeros(Value bitorkey,
+ Index count[DIGITS][DIGIT_VALUES], unsigned *shift, Index **offsets)
+ unsigned digits = 0, sh = 0;
+ Index *c = &count[0][0];
+ do
+ if (bitorkey & DIGIT_MASK)
+ *shift++ = sh, *offsets++ = c, ++digits, radix_offsets(c);
+ } while (bitorkey >>= DIGIT_BITS,sh += DIGIT_BITS,c += DIGIT_VALUES,sh
+ != VALUE_BITS);
+ return digits;
+void TupleList::radix_index_pass_b(const Value *A, Index n, Index stride,
+ unsigned sh, Index *off, SortData<Value> *out)
+ Index i = 0;
+ do
+ Value v = *A;
+ SortData<Value> *d = &out[off[(v >> sh) & DIGIT_MASK]++];
+ d->v = v, d->i = i++;
+ } while (A += stride, i != n);
+void TupleList::radix_index_pass_m(const SortData<Value> *src,
+ const SortData<Value> *end, unsigned sh, Index *off, SortData<Value> *out)
+ do
+ SortData<Value> *d = &out[off[(src->v >> sh) & DIGIT_MASK]++];
+ d->v = src->v, d->i = src->i;
+ } while (++src != end);
+void TupleList::radix_index_pass_e(const SortData<Value> *src,
+ const SortData<Value> *end, unsigned sh, Index *off, Index *out)
+ do
+ out[off[(src->v >> sh) & DIGIT_MASK]++] = src->i;
+ while (++src != end);
+void TupleList::radix_index_pass_be(const Value *A, Index n, Index stride,
+ unsigned sh, Index *off, Index *out)
+ Index i = 0;
+ do
+ out[off[(*A >> sh) & DIGIT_MASK]++] = i++;
+ while (A += stride, i != n);
+void TupleList::radix_index_sort(const Value *A, Index n, Index stride,
+ Index *idx, SortData<Value> *work)
+ Index count[DIGITS][DIGIT_VALUES];
+ Value bitorkey = radix_count(A, A + n * stride, stride, count);
+ unsigned shift[DIGITS];
+ Index *offsets[DIGITS];
+ unsigned digits = radix_zeros(bitorkey, count, shift, offsets);
+ if (digits == 0)
+ Index i = 0;
+ do
+ *idx++ = i++;
+ while (i != n);
+ else if (digits == 1)
+ radix_index_pass_be(A, n, stride, shift[0], offsets[0], idx);
+ else
+ SortData<Value> *src, *dst;
+ unsigned d;
+ if ((digits & 1) == 0)
+ dst = work, src = dst + n;
+ else
+ src = work, dst = src + n;
+ radix_index_pass_b(A, n, stride, shift[0], offsets[0], src);
+ for (d = 1; d != digits - 1; ++d)
+ SortData<Value> *t;
+ radix_index_pass_m(src, src + n, shift[d], offsets[d], dst);
+ t = src, src = dst, dst = t;
+ radix_index_pass_e(src, src + n, shift[d], offsets[d], idx);
+void TupleList::merge_index_sort(const Value *A, const Index An, Index stride,
+ SortData<Value> * const buf[2] = { work + An, work };
+ Index n = An, base = -n, odd = 0, c = 0, b = 1;
+ Index i = 0;
+ for (;;)
+ SortData<Value> *p;
+ if ((c & 1) == 0)
+ base += n, n += (odd & 1), c |= 1, b ^= 1;
+ while (n > 3)
+ odd <<= 1, odd |= (n & 1), n >>= 1, c <<= 1, b ^= 1;
+ else
+ base -= n - (odd & 1), n <<= 1, n -= (odd & 1), odd >>= 1, c >>= 1;
+ if (c == 0)
+ break;
+ p = buf[b] + base;
+ if (n == 2)
+ Value v[2];
+ v[0] = *A, A += stride, v[1] = *A, A += stride;
+ if (v[1] < v[0])
+ p[0].v = v[1], p[0].i = i + 1, p[1].v = v[0], p[1].i = i;
+ else
+ p[0].v = v[0], p[0].i = i, p[1].v = v[1], p[1].i = i + 1;
+ i += 2;
+ else if (n == 3)
+ Value v[3];
+ v[0] = *A, A += stride, v[1] = *A, A += stride, v[2] = *A, A += stride;
+ if (v[1] < v[0])
+ if (v[2] < v[1])
+ p[0].v = v[2], p[1].v = v[1], p[2].v = v[0], p[0].i = i + 2, p[1].i =
+ i + 1, p[2].i = i;
+ else
+ if (v[2] < v[0])
+ p[0].v = v[1], p[1].v = v[2], p[2].v = v[0], p[0].i = i + 1, p[1].i =
+ i + 2, p[2].i = i;
+ else
+ p[0].v = v[1], p[1].v = v[0], p[2].v = v[2], p[0].i = i + 1, p[1].i =
+ i, p[2].i = i + 2;
+ else
+ if (v[2] < v[0])
+ p[0].v = v[2], p[1].v = v[0], p[2].v = v[1], p[0].i = i + 2, p[1].i =
+ i, p[2].i = i + 1;
+ else
+ if (v[2] < v[1])
+ p[0].v = v[0], p[1].v = v[2], p[2].v = v[1], p[0].i = i, p[1].i = i
+ + 2, p[2].i = i + 1;
+ else
+ p[0].v = v[0], p[1].v = v[1], p[2].v = v[2], p[0].i = i, p[1].i = i
+ + 1, p[2].i = i + 2;
+ i += 3;
+ else
+ const Index na = n >> 1, nb = (n + 1) >> 1;
+ const SortData<Value> *ap = buf[b ^ 1] + base, *ae = ap + na;
+ SortData<Value> *bp = p + na, *be = bp + nb;
+ for (;;)
+ if (bp->v < ap->v)
+ *p++ = *bp++;
+ if (bp != be)
+ continue;
+ do
+ *p++ = *ap++;
+ while (ap != ae);
+ break;
+ else
+ *p++ = *ap++;
+ if (ap == ae)
+ break;
+ const SortData<Value> *p = buf[0], *pe = p + An;
+ do
+ *idx++ = (p++)->i;
+ while (p != pe);
+void TupleList::index_sort(const Value *A, Index n, Index stride, Index *idx,
+ SortData<Value> *work)
+ if (n < DIGIT_VALUES)
+ if (n == 0)
+ return;
+ if (n == 1)
+ *idx = 0;
+ else
+ merge_index_sort(A, n, stride, idx, work);
+ else
+ radix_index_sort(A, n, stride, idx, work);
+#undef DIGIT_BITS
+#undef DIGIT_VALUES
+#undef DIGIT_MASK
+#undef CEILDIV
+#undef DIGITS
+#undef VALUE_BITS
+#undef COUNT_SIZE
+#undef sort_data_long
+} //namespace
diff --git a/src/moab/TupleList.hpp b/src/moab/TupleList.hpp
index 0000000..8cbd388
--- /dev/null
+++ b/src/moab/TupleList.hpp
@@ -0,0 +1,413 @@
+ Tuple list definition and utilities
+ Conceptually, a tuple list is a list of n records or tuples,
+ each with mi integers, ml longs, mul ulongs, and mr reals
+ (these types are defined in "types.h" as sint, slong, sulong, real;
+ it may be that sint==slong)
+ There are four arrays, one for each type (vi,vl,vul,vr),
+ with records layed out contiguously within each array
+#ifndef TUPLE_LIST_HPP
+#define TUPLE_LIST_HPP
+#include "moab/Types.hpp"
+#include <string>
+/* Integral types defined here to ensure variable type sizes are consistent */
+/* integer type to use for everything */
+#if defined(USE_LONG)
+# define INTEGER long
+#elif defined(USE_LONG_LONG)
+# define INTEGER long long
+#elif defined(USE_SHORT)
+# define INTEGER short
+#else
+# define INTEGER int
+#endif
+/* when defined, use the given type for global indices instead of INTEGER */
+#if defined(USE_GLOBAL_LONG_LONG)
+# define GLOBAL_INT long long
+#elif defined(USE_GLOBAL_LONG)
+#else
+#endif
+/* floating point type to use for everything */
+#if defined(USE_FLOAT)
+typedef float realType;
+# define floorr floorf
+# define ceilr ceilf
+# define sqrtr sqrtf
+# define fabsr fabsf
+# define cosr cosf
+# define sinr sinf
+# define EPS (128*FLT_EPSILON)
+# define PI 3.1415926535897932384626433832795028841971693993751058209749445923F
+#elif defined(USE_LONG_DOUBLE)
+typedef long double realType;
+# define floorr floorl
+# define ceilr ceill
+# define sqrtr sqrtl
+# define fabsr fabsl
+# define cosr cosl
+# define sinr sinl
+# define EPS (128*LDBL_EPSILON)
+# define PI 3.1415926535897932384626433832795028841971693993751058209749445923L
+#else
+typedef double realType;
+# define cosr cos
+# define sinr sin
+# define EPS (128*DBL_EPSILON)
+#endif
+/* apparently uint and ulong can be defined already in standard headers */
+#define uint uint_
+#define ulong ulong_
+#define sint sint_
+#define slong slong_
+typedef signed INTEGER sint;
+typedef unsigned INTEGER uint;
+#undef INTEGER
+#ifdef GLOBAL_INT
+typedef signed GLOBAL_INT slong;
+typedef unsigned GLOBAL_INT ulong;
+#else
+typedef sint slong;
+typedef uint ulong;
+#endif
+namespace moab
+ void fail(const char *fmt, ...);
+ class TupleList
+ public:
+ buffer: a simple class which can be used to store data
+ The ptr points to the chunk of memory allocated for the buffer's use. The
+ size denotes the size of the allocated memory; the user must take care to
+ note how much of the buffer they are using.
+ class buffer
+ public:
+ size_t buffSize;
+ char *ptr;
+ /**Constructor which sets an initial capacity of the buffer
+ buffer(size_t sz);
+ /**Default constructor (Note: buffer must be initialized before use!)
+ buffer();
+ ~buffer () { this->reset(); };
+ /**Initializes the buffer to have a capacity of size
+ void buffer_init_(size_t sz, const char *file);
+ /**Ensures that the buffer has at least a capacity of min
+ void buffer_reserve_(size_t min, const char *file);
+ /**Frees any allocated memory used by the buffer
+ void reset ();
+ //Aliases for using the buffer methods
+#define buffer_init(sz) buffer_init_(sz,__FILE__)
+#define buffer_reserve(min) buffer_reserve_(min,__FILE__)
+ public:
+ /**Constructor that takes all parameters and initializes the TupleList
+ TupleList(uint mi, uint ml,
+ uint mul, uint mr, uint max);
+ /**Default constructor (Note: TupleList must be initialized before use!)
+ TupleList();
+ ~TupleList() { reset(); };
+ /**Initializes the starting memory to be used by the TupleList
+ * Note: TupleLists must be initialized before they can be used
+ * param mi number of signed ints in each tuple
+ * param ml number of long ints in each tuple
+ * param mul number of unsigned long ints in each tuple
+ * param mr number of reals in each tuple
+ * param max starting capacity of max tuples in the TupleList
+ void initialize(uint mi, uint ml,
+ /**Resizes the TupleList to a new max
+ * param max the new max capacity of the TupleList
+ ErrorCode resize(uint max);
+ /**Sorts the TupleList by 'key'
+ * if key<mi: key represents the key'th index in vi
+ * if mi<key<ml: key represents the (key-mi)'th index in vl
+ * if ml<key<mul: key represents the (key-mi-ml)'th index in vul
+ * param key index to be sorted by
+ * param *buf buffer space used for sorting
+ Hybrid Stable Sort
+ low-overhead merge sort when n is small,
+ otherwise asymptotically superior radix sort
+ result = O(n) sort with good performance for all n
+ A, n, stride : specifices the input
+ sort:
+ uint out[n] : the sorted values (output)
+ uint work[n]: scratch area
+ index_sort:
+ uint idx[n] : the sorted indices (output)
+ sort_data work[2*n]: scratch area
+ ErrorCode sort(uint key, TupleList::buffer *buf);
+ /**Frees all allocated memory in use by the TupleList
+ void reset();
+ /**Adds one to the total number of in-use tuples and resizes if necessary
+ void reserve();
+ /**Finds index of the tuple containing 'value' at the key_numth index of
+ * said tuple; return -1 if key_num is out of bounds or if 'value' not found
+ * Uses binary search if TupleList is sorted by the key_numth field, seqential
+ * otherwise (very slow for large TupleLists; please sort before you search)
+ * param key_num index of the tuple where to search for value
+ * param value value to search for at the given key_num
+ * return the index of the tuple that contains value
+ int find(unsigned int key_num, sint value);
+ int find(unsigned int key_num, slong value);
+ int find(unsigned int key_num, ulong value);
+ int find(unsigned int key_num, realType value);
+ /**get the mth number of return type in the index'th tuple
+ * returns 0 if m or index is out of bounds
+ * param index index of the tuple within the TupleList
+ * param m index of the value within the tuple
+ * return the value at the given position
+ sint get_sint(unsigned int index, unsigned int m);
+ slong get_int(unsigned int index, unsigned int m);
+ ulong get_ulong(unsigned int index, unsigned int m);
+ realType get_double(unsigned int index, unsigned int m);
+ /**get pointers to the data for the index'th tuple; ptr is
+ * NULL if that type is not part of this tuple
+ * param index index of the tuple needed
+ * param *&sp, *&ip, *&lp, *&dp pointers to each piece of the tuple
+ ErrorCode get(unsigned int index, const sint *&sp,
+ const slong *&ip, const ulong *&lp, const realType *&dp);
+ /**push back a new tuple on the TupleList;
+ * param *sp pointer to a list of signed ints
+ * param *ip pointer to a list of signed longs
+ * param *lp pointer to a list of unsigned longs
+ * param *dp pointer to a list of reals
+ * return index of that tuple
+ unsigned int push_back(sint *sp, slong *ip,
+ ulong *lp, realType *dp);
+ /*Enable or disable direct write access to arrays
+ This is important so that we know whether or not
+ the user of this class can directly modify data
+ which can affect operations such as
+ whether or not we know the tuple list is sorted
+ (for a binary search)*/
+ void enableWriteAccess();
+ void disableWriteAccess();
+ /*Get information on the Tuple Sizes
+ * param &mi_out Count of uints in a tuple
+ * param &ml_out Count of uints in a tuple
+ * param &mul_out Count of uints in a tuple
+ * param &mr_out Count of uints in a tuple
+ void getTupleSize(uint &mi_out, uint &ml_out,
+ uint &mul_out, uint &mr_out) const;
+ /*Set the count of Tuples in the Tuple List
+ * Warning, automatically calls enableWriteAccess()
+ * param n_in New count of Tuples
+ void set_n(uint n_in);
+ /* Get the count of Tuples in the Tuple List */
+ uint get_n() const;
+ /*Get the maximum number of Tuples currently allocated for*/
+ uint get_max() const;
+ bool get_writeEnabled() const;
+ /*Increment n by 1
+ * returns current TupleList.n after the increment */
+ uint inc_n();
+ void print(const char *) const;
+ //Variables to allow for direct write access
+ sint *vi_wr; slong *vl_wr; ulong *vul_wr; realType *vr_wr;
+ //Variables to allow for direct read access
+ const sint *vi_rd; slong *vl_rd; ulong *vul_rd; realType *vr_rd;
+ private:
+ /* storage layed out as: vi[max][mi], vl[max][ml], vul[max][mul],
+ * vr[max][mr] where "tuple" i is given by
+ * (vi[i][0:mi-1],vl[i][0:ml-1],vul[i][0:mul-1],vr[i][0:mr-1]).
+ * only the first n tuples are in use */
+ uint mi,ml,mul,mr;
+ uint n, max;
+ sint *vi; slong *vl; ulong *vul; realType *vr;
+ // Used by sort: see .cpp for more details
+ //void sort_bits(uint *work, uint key);
+ void permute(uint *perm, void *work);
+ /* last_sorted = the last sorted position in the tuple (if the
+ * TupleList has not been sorted, or has become unsorted--i.e.
+ * by adding a tuple--last_sorted = -1) */
+ int last_sorted;
+ //Whether or not the object is currently allowing direct
+ //write access to the arrays
+ bool writeEnabled;
+ typedef uint Index;
+ template <typename Value>
+ struct SortData {Value v; Index i;};
+ template<class Value>
+ static Value radix_count(const Value *A, const Value *end, Index stride,
+ Index count[DIGITS][DIGIT_VALUES]);
+ static void radix_offsets(Index *c);
+ static unsigned radix_zeros(Value bitorkey, Index count[DIGITS][DIGIT_VALUES],
+ unsigned *shift, Index **offsets);
+ static void radix_index_pass_b(const Value *A, Index n, Index stride,
+ unsigned sh, Index *off, SortData<Value> *out);
+ static void radix_index_pass_m(const SortData<Value> *src, const SortData<Value> *end,
+ static void radix_index_pass_e(const SortData<Value> *src, const SortData<Value> *end,
+ unsigned sh, Index *off, Index *out);
+ static void radix_index_pass_be(const Value *A, Index n, Index stride,
+ Radix Sort
+ stable; O(n) time
+ static void radix_index_sort(const Value *A, Index n, Index stride,
+ Index *idx, SortData<Value> *work);
+ Merge Sort
+ stable; O(n log n) time
+ static void merge_index_sort(const Value *A, const Index An, Index stride,
+ static void index_sort(const Value *A, Index n, Index stride,
+#undef DIGIT_BITS
+#undef DIGIT_MASK
+#undef CEILDIV
+#undef DIGITS
+#undef VALUE_BITS
+#undef COUNT_SIZE
+ inline uint TupleList::get_max() const{ return max; }
+ inline uint TupleList::get_n() const{ return n; }
+ inline bool TupleList::get_writeEnabled() const{ return writeEnabled; }
+} //namespace
+#endif
diff --git a/src/parallel/Makefile.am b/src/parallel/Makefile.am
index 2718263..b80b85e 100644
--- a/src/parallel/Makefile.am
+++ b/src/parallel/Makefile.am
@@ -34,8 +34,7 @@ if PARALLEL
ReadParallel.hpp \
SharedSetData.cpp \
SharedSetData.hpp \
- gs.cpp \
- TupleList.cpp
+ gs.cpp
# The list of header files which are to be installed
@@ -47,8 +46,7 @@ if PARALLEL
moab/ParallelMergeMesh.hpp \
moab/ProcConfig.hpp \
moab/ParallelData.hpp \
- MBParallelConventions.h \
- moab/TupleList.hpp
+ MBParallelConventions.h
if PARALLEL_HDF5
# libMOABpar_la_LIBADD = $(top_builddir)/mhdf/libmhdf.la
This diff is so big that we needed to truncate the remainder.
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
