[MOAB-dev] r5930 - MOAB/trunk/src
tautges at mcs.anl.gov
Tue Dec 18 16:47:36 CST 2012
Author: tautges
Date: 2012-12-18 16:47:35 -0600 (Tue, 18 Dec 2012)
New Revision: 5930
Modified:
MOAB/trunk/src/Core.cpp
Log:
Removing an unaccessed block of code, good spot Iulian.
Modified: MOAB/trunk/src/Core.cpp
--- MOAB/trunk/src/Core.cpp 2012-12-18 22:08:43 UTC (rev 5929)
+++ MOAB/trunk/src/Core.cpp 2012-12-18 22:47:35 UTC (rev 5930)
@@ -2900,21 +2900,8 @@
std::cout << std::endl;
- // if negative num_entities, list the set hierarchy too
- if (0 > num_entities) {
- Range sets;
- result = this->get_entities_by_type(0, MBENTITYSET, sets);
- if (MB_SUCCESS != result) return result;
- for (Range::iterator rit = sets.begin(); rit != sets.end(); rit++) {
- this->print(*rit, "", true);
- result = this->get_number_entities_by_handle(*rit, num_ents);
- std::cout << "(" << num_ents << " total entities)" << std::endl;
return MB_SUCCESS;
else if (NULL == entities && num_entities < 0) {
// list all entities of all types
@@ -2925,7 +2912,6 @@
return list_entities(temp_range);
else if (NULL == entities && num_entities > 0) {
// list all entities of type == num_entities
@@ -2934,7 +2920,6 @@
else {
ErrorCode tmp_result;
for (int i = 0; i < num_entities; i++) {
