[MOAB-dev] r5928 - in MOAB/trunk: src src/moab test
tautges at mcs.anl.gov
Tue Dec 18 15:09:41 CST 2012
Author: tautges
Date: 2012-12-18 15:09:41 -0600 (Tue, 18 Dec 2012)
New Revision: 5928
Modified:
MOAB/trunk/src/BitTag.cpp
MOAB/trunk/src/BitTag.hpp
MOAB/trunk/src/Core.cpp
MOAB/trunk/src/DenseTag.cpp
MOAB/trunk/src/DenseTag.hpp
MOAB/trunk/src/MeshTag.cpp
MOAB/trunk/src/MeshTag.hpp
MOAB/trunk/src/SparseTag.cpp
MOAB/trunk/src/SparseTag.hpp
MOAB/trunk/src/TagInfo.hpp
MOAB/trunk/src/VarLenDenseTag.cpp
MOAB/trunk/src/VarLenDenseTag.hpp
MOAB/trunk/src/VarLenSparseTag.cpp
MOAB/trunk/src/VarLenSparseTag.hpp
MOAB/trunk/src/moab/Core.hpp
MOAB/trunk/src/moab/Interface.hpp
MOAB/trunk/test/TagTest.cpp
Log:
Change to tag_iterate, to allow application to request that tag storage space not be allocated.
This commit also modifies interpretation of arguments to the Core::list_entities function, see
below for details.
Fixes tickets 271 and 268.
Passes all tests, serial and parallel.
TagTest.cpp: add a test for ticket #271, where apps could change the default value of a tag
(that bug is also fixed in this commit)
Most tag classes, plus Core and Interface: add an allocate parameter to tag_iterate, allowing applications to request that tag
memory not be allocated as a result of calling this function.
SparseTag: fix the bug exposing tag default value, along with allocation change above
Core: modified meaning of arguments to Core::list_entities(EntityHandle*entities, int num_entities); if entities == NULL, then
num_entities < 0 : list the whole database
== 0: list the number of entities of each type
> 0 : list all entities of type == (EntityType)num_entities
This makes debugging significantly easier, since you don't need to assemble an entity range
or vector to print e.g. all entity sets
Modified: MOAB/trunk/src/BitTag.cpp
--- MOAB/trunk/src/BitTag.cpp 2012-12-18 19:23:22 UTC (rev 5927)
+++ MOAB/trunk/src/BitTag.cpp 2012-12-18 21:09:41 UTC (rev 5928)
@@ -332,7 +332,8 @@
Error* error,
Range::iterator&,
const Range::iterator&,
- void*& )
+ void*&,
+ bool )
{ return report_unsupported(error); }
template <class Container> inline
Modified: MOAB/trunk/src/BitTag.hpp
--- MOAB/trunk/src/BitTag.hpp 2012-12-18 19:23:22 UTC (rev 5927)
+++ MOAB/trunk/src/BitTag.hpp 2012-12-18 21:09:41 UTC (rev 5928)
@@ -292,7 +292,8 @@
Error* error_handler,
Range::iterator& iter,
const Range::iterator& end,
- void*& data_ptr );
+ void*& data_ptr,
+ bool allocate = true);
/**\brief Get all tagged entities
Modified: MOAB/trunk/src/Core.cpp
--- MOAB/trunk/src/Core.cpp 2012-12-18 19:23:22 UTC (rev 5927)
+++ MOAB/trunk/src/Core.cpp 2012-12-18 21:09:41 UTC (rev 5928)
@@ -2483,11 +2483,13 @@
Range::const_iterator iter,
Range::const_iterator end,
int& count,
- void*& data_ptr )
+ void*& data_ptr,
+ bool allocate)
Range::const_iterator init = iter;
assert(valid_tag_handle( tag_handle ));
- ErrorCode result = tag_handle->tag_iterate( sequenceManager, mError, iter, end, data_ptr );
+ ErrorCode result = tag_handle->tag_iterate( sequenceManager, mError, iter, end, data_ptr,
+ allocate);
if (MB_SUCCESS == result)
count = iter - init;
return result;
@@ -2887,7 +2889,7 @@
