[MOAB-dev] r5909 - in MOAB/trunk: . tools
    tautges at mcs.anl.gov
    Thu Dec 13 11:22:58 CST 2012
Author: tautges
Date: 2012-12-13 11:22:58 -0600 (Thu, 13 Dec 2012)
New Revision: 5909
Modified:
   MOAB/trunk/RELEASE_NOTES
   MOAB/trunk/configure.ac
   MOAB/trunk/tools/Makefile.am
Log:
A bit better autotools searching magic for vtk.  Disable compiling vtkMOABReader
through make-based build (should use cmake for that, see tools/vtkMOABReader/README).
Adding many release notes in anticipation of 4.6 release.
Modified: MOAB/trunk/RELEASE_NOTES
--- MOAB/trunk/RELEASE_NOTES	2012-12-12 23:06:12 UTC (rev 5908)
+++ MOAB/trunk/RELEASE_NOTES	2012-12-13 17:22:58 UTC (rev 5909)
@@ -1,6 +1,24 @@
 Version 4.6pre:
 * Added Interface::adjacencies_iterate, whose behavior is much like tag_iterate.
 * Extended Interface::get_coords, to return entity centroids (avg vertex position) for non-vertex entities instead of failing
+* Added new iMeshP extension function iMeshP_getCommunicator, converting fortran integer to MPI C communicator
+* Various bug fixes and improvements of mbcoupler (parallel mesh to mesh transfer): handling of spectral elements, works in
+  serial now, better tolerancing for point searches
+* New conventions for handling spectral element types; see doc/metadata_info.doc for details
+* New options for mbsize, similar to those for mbconvert (allows user to specify parallel reading options, so mbsize can be
+  run as a parallel reading test)
+* Initial implementation of Damsel reader/writer
+* Major enhancements, efficiency improvements for NC data reader, including going mostly to a 2.5D representation, addition
+  of a HOMME data reader, bug fixes in representing periodic meshes in parallel
+* Initial implementation of a GCRM data reader, and a better ReadTemplate class (skeleton for writing new readers)
+* Add new metadata and properties handling to DAGMC
+* More extensive warning reporting when using GCC compilers, and many warning eliminations
+* Support for 1D in structured mesh interface
+* Improved doxygen developer documentation
+* Improved vtkMOABReader & paraview plugin
+* Additions/improvements to examples
+* New performance tests that include direct tag access tests
+* Undeprecated one of the "tag_get_handle" functions for returning tag handle given tag name
 Version 4.5:
 * ITAPS: added iMesh_stepEntIter, iMesh_stepEntArrIter, iMesh_tagIterate, iMesh_createTagWithOptions (see iMesh_extensions.h)
@@ -8,6 +26,7 @@
 * Error class exposed in API, and query_interface now supports getting access to the moab::Core member of that class.
 * Added Interface::coords_iterate and Interface::connect_iterate, analogous to tag_iterate (allows direct access to
   coordinate and connectivity memory for blocks of entity handles)
+* Added new iMeshP extension tag_reduce
 Version 4.1:
 * Structured mesh API (see src/moab/ScdInterface.hpp)
Modified: MOAB/trunk/configure.ac
--- MOAB/trunk/configure.ac	2012-12-12 23:06:12 UTC (rev 5908)
+++ MOAB/trunk/configure.ac	2012-12-13 17:22:58 UTC (rev 5909)
@@ -569,7 +569,23 @@
   VTKMOAB_DEFAULT=yes
 fi
+AC_ARG_WITH( [vtk-lib-suffix],
+             [AC_HELP_STRING([--with-vtk-lib-suffix=SUFFIX],[Specify optional suffix to VTK library names, e.g. -pv3.98])],
+             [case "x$withval" in
+               xyes)
+                 AC_MSG_ERROR([Must specify a non-empty suffix!])
