[MOAB-dev] r5895 - in MOAB/trunk: src src/io src/moab test/parallel
iulian at mcs.anl.gov
Tue Dec 4 15:14:02 CST 2012
Author: iulian
Date: 2012-12-04 15:14:02 -0600 (Tue, 04 Dec 2012)
New Revision: 5895
Modified:
MOAB/trunk/src/Util.cpp
MOAB/trunk/src/io/ReadNC.cpp
MOAB/trunk/src/io/ReadNC.hpp
MOAB/trunk/src/moab/Util.hpp
MOAB/trunk/test/parallel/Makefile.am
MOAB/trunk/test/parallel/ucdtrvpart.cpp
Log:
fix the ucdtrvpart test
resolve_shared_ents works now for ucd reader;
added utility to get the gather set and entities
the file_id_tag and global id tag are now different tags
global id tag will be used by gather to identify the entities to gather to
file_id_tag will continue to be used for resolving shared entities
Modified: MOAB/trunk/src/Util.cpp
--- MOAB/trunk/src/Util.cpp 2012-12-01 00:05:56 UTC (rev 5894)
+++ MOAB/trunk/src/Util.cpp 2012-12-04 21:14:02 UTC (rev 5895)
@@ -177,5 +177,33 @@
+ErrorCode Util::gather_set(Interface * MB, EntityHandle & gather_set){
+ Tag gathersettag;
+ ErrorCode rval = MB->tag_get_handle("GATHER_SET", 1, MB_TYPE_INTEGER, gathersettag,
+ MB_TAG_SPARSE);
+ if (rval!=MB_SUCCESS)
+ return rval;
+ int gatherval = 1;
+ void *vals[] = {&gatherval};
+ Range gathersets;
+ rval = MB->get_entities_by_type_and_tag( 0, MBENTITYSET, &gathersettag,
+ vals, 1, gathersets );
+ return rval;
+ if (gathersets.empty())
+ return MB_ENTITY_NOT_FOUND;
+ gather_set = gathersets[0];
+ return MB_SUCCESS;
+ErrorCode Util::gather_set_entities(Interface * MB, EntityHandle & gather_set, Range & ents)
+ ErrorCode rval = Util::gather_set(MB, gather_set);
+ return rval;
+ rval = MB->get_entities_by_handle(gather_set, ents);
+ return rval;
} // namespace moab
Modified: MOAB/trunk/src/io/ReadNC.cpp
--- MOAB/trunk/src/io/ReadNC.cpp 2012-12-01 00:05:56 UTC (rev 5894)
+++ MOAB/trunk/src/io/ReadNC.cpp 2012-12-04 21:14:02 UTC (rev 5895)
@@ -35,7 +35,7 @@
ReadNC::ReadNC(Interface* impl) :
mbImpl(impl), CPU_WORD_SIZE(-1), IO_WORD_SIZE(-1), fileId(-1), tMin(-1), tMax(-1), iDim(-1), jDim(-1), tDim(-1), iCDim(-1),
- jCDim(-1), numUnLim(-1), mCurrentMeshHandle(0), startVertex(0), startElem(0), mGlobalIdTag(0), max_line_length(-1),
+ jCDim(-1), numUnLim(-1), mCurrentMeshHandle(0), startVertex(0), startElem(0), mGlobalIdTag(0), mpFileIdTag(NULL), max_line_length(-1),
max_str_length(-1), vertexOffset(0), dbgOut(stderr), isParallel(false), partMethod(-1), camType(NOT_CAM), isCf(false),
spectralOrder(-1), npMesh(false),
