[MOAB-dev] r5888 - in MOAB/trunk: src/io tools/mbcoupler
iulian at mcs.anl.gov
Wed Nov 28 12:51:07 CST 2012
Author: iulian
Date: 2012-11-28 12:51:07 -0600 (Wed, 28 Nov 2012)
New Revision: 5888
Modified:
MOAB/trunk/src/io/ReadNC.cpp
MOAB/trunk/tools/mbcoupler/Coupler.cpp
Log:
put in the partition set only nodes connected to the quads
Modified: MOAB/trunk/src/io/ReadNC.cpp
--- MOAB/trunk/src/io/ReadNC.cpp 2012-11-28 01:37:26 UTC (rev 5887)
+++ MOAB/trunk/src/io/ReadNC.cpp 2012-11-28 18:51:07 UTC (rev 5888)
@@ -238,13 +238,17 @@
rval = mbImpl->create_meshset(MESHSET_SET, partn_set);
ERRORR(rval, "Trouble creating partition set.");
+ rval = mbImpl->add_entities(partn_set,quads);
+ ERRORR(rval, "Couldn't add new quads to partition set.");
Range verts;
- mbImpl->get_entities_by_type(0, MBVERTEX, verts);
- mbImpl->add_entities(partn_set,quads);
- mbImpl->add_entities(partn_set,verts);
+ rval = mbImpl->get_connectivity(quads, verts);
+ ERRORR(rval, "Couldn't get verts of quads");
+ rval = mbImpl->add_entities(partn_set,verts);
+ ERRORR(rval, "Couldn't add new verts to partition set.");
myPcomm->partition_sets().insert(partn_set);
- rval = mbImpl->add_entities(partn_set, quads);
- ERRORR(rval, "Couldn't add new quads to partition set.");
#if 0
if (ucdMesh && !noVars)
Modified: MOAB/trunk/tools/mbcoupler/Coupler.cpp
--- MOAB/trunk/tools/mbcoupler/Coupler.cpp 2012-11-28 01:37:26 UTC (rev 5887)
+++ MOAB/trunk/tools/mbcoupler/Coupler.cpp 2012-11-28 18:51:07 UTC (rev 5888)
@@ -638,7 +638,7 @@
// find natural coordinates of point in element(s) in that leaf
CartVect tmp_nat_coords;
Range range_leaf;
- result = mbImpl->get_entities_by_dimension(closest_leaf, 3, range_leaf, false);
+ result = mbImpl->get_entities_by_dimension(closest_leaf, max_dim, range_leaf, false);
if(result != MB_SUCCESS) std::cout << "Problem getting leaf in a range" << std::endl;
// loop over the range_leaf
