[MOAB-dev] r5877 - in MOAB/trunk: test/parallel tools/mbcslam
iulian at mcs.anl.gov
Fri Nov 16 22:15:38 CST 2012
Author: iulian
Date: 2012-11-16 22:15:38 -0600 (Fri, 16 Nov 2012)
New Revision: 5877
Modified:
MOAB/trunk/test/parallel/par_intx_sph.cpp
MOAB/trunk/tools/mbcslam/Intx2Mesh.hpp
Log:
update adjacencies of manufactured mesh, for intersection example, so the
resolve sharing can succeed. Still at manufacturing stage
also, make the members of Intx2Mesh base class protected
Modified: MOAB/trunk/test/parallel/par_intx_sph.cpp
--- MOAB/trunk/test/parallel/par_intx_sph.cpp 2012-11-16 22:43:25 UTC (rev 5876)
+++ MOAB/trunk/test/parallel/par_intx_sph.cpp 2012-11-17 04:15:38 UTC (rev 5877)
@@ -100,8 +100,9 @@
// get the coordinates of the old mesh, and move it around the sphere in the same way as in the
// python script
- // fill the conn arr with the old one, then modify it to kep the new vertices
+ // fill the conn arr with the old one, then modify it to point to the new vertices
unsigned int shift = start_vertex-connecVerts[0];
+ EntityHandle * ptr_conn=conn_arr;
for (Range::iterator qit=quads.begin(); qit!=quads.end(); qit++)
EntityHandle eh=*qit;
@@ -110,10 +111,14 @@
rval = mb->get_connectivity(eh, conn4, num_nodes);
CHECK_ERR(rval);
for (int i=0; i<4; i++)
- conn_arr[i]=conn4[i]+shift;
- conn_arr+=4; // advance pointer in array
+ ptr_conn[i]=conn4[i]+shift;
+ ptr_conn+=4; // advance pointer in array
+ // notify to update the adjacencies; they will be used to resolve shared nodes on the new mesh
+ rval = readMeshIface->update_adjacencies(start_quad, quads.size(),
+ 4, conn_arr);
+ CHECK_ERR(rval);
// now put the vertices in the right place....
int vix=0; // vertex index in new array
double t=0.1, T=5;// check the script
@@ -198,6 +203,7 @@
((int*)data2)[i]= ((int*)data)[i];
ParallelComm* pcomm = ParallelComm::get_pcomm(mb, 0);
+ pcomm->set_debug_verbosity(2);
rval = pcomm->resolve_shared_ents(0, new_meshRange, 2, 0);
CHECK_ERR(rval);
@@ -233,4 +239,9 @@
rval = mb.write_file("manuf.h5m", 0, opts_write.c_str(), &lagrange_set, 1);
CHECK_ERR(rval);
+ // now, we know that each processor has an euler set and a lagrange set
+ // compute the intersection in a third set
