[MOAB-dev] r5875 - MOAB/trunk/src/io
iulian at mcs.anl.gov
Fri Nov 16 15:00:08 CST 2012
Author: iulian
Date: 2012-11-16 15:00:08 -0600 (Fri, 16 Nov 2012)
New Revision: 5875
Modified:
MOAB/trunk/src/io/ReadNC.cpp
Log:
look for ncells or ncenters in HommeMapping file
Modified: MOAB/trunk/src/io/ReadNC.cpp
--- MOAB/trunk/src/io/ReadNC.cpp 2012-11-16 20:44:52 UTC (rev 5874)
+++ MOAB/trunk/src/io/ReadNC.cpp 2012-11-16 21:00:08 UTC (rev 5875)
@@ -682,7 +682,21 @@
// read connectivity into temporary variable
int num_fine_quads, num_coarse_quads, start_idx;
- int num_quads = conn_vals[2];
+ std::vector<std::string>::iterator vit;
+ int idx;
+ if ( (vit = std::find(conn_names.begin(), conn_names.end(), "ncells")) != conn_names.end())
+ idx = vit - conn_names.begin();
+ else if ( (vit = std::find(conn_names.begin(), conn_names.end(), "ncenters")) != conn_names.end())
+ idx=vit - conn_names.begin();
+ else
+ ERRORR(MB_FAILURE, "Failed to get number of quads.");
+ int num_quads=conn_vals[idx];
// get the connectivity into tmp_conn2 and permute into tmp_conn
int cornerVarId;
@@ -891,10 +905,23 @@
ERRORR(MB_FAILURE, "Connectivity file didn't have correct dimension names.");
- int num_quads = 0;
- if (conn_names[2]=="ncells")
- num_quads = conn_vals[2];
- if (conn_vals[2] != gDims[3] - gDims[0] + 1-2) {
+ int idx;
+ if ((vit = std::find(conn_names.begin(), conn_names.end(), "ncells")) != conn_names.end())
+ else if ((vit = std::find(conn_names.begin(), conn_names.end(), "ncenters")) != conn_names.end())
+ else
