[MOAB-dev] latest spectral mesh document
Tim Tautges
tautges at mcs.anl.gov
Fri Nov 2 10:15:47 CDT 2012
Hi all,
Here's the latest version of the document. I repeat here the conclusion, which describes what I'm planning to do in
MOAB's representation:
In brief, we propose to represent elements using the linear, FE-ordered connectivity list (containing only corner
vertices from the spectral element), with field variables written to either vertices, lexicographically-ordered arrays
on elements, or both, and with a lexicographically-ordered array of all (corner+higher-order) vertices stored on
elements. In the either/or case, the choice will be evident from the tag size and the entities on which the tag is set.
In the both case, the tag name will have a “-LEX” suffix for the element tags, and the size of the element tag will be
(N+1)^2 times that of the vertex-based tag. Finally, the file set containing the spectral elements (or the root set, if
no file set was input to the read) will contain a “SPECTRAL_ORDER” tag whose value is N.
Comments welcome.
- tim
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone (gvoice): (608) 354-1459 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
