[MOAB-dev] r5843 - in MOAB/trunk: src/lotte src/moab/point_locater/lotte test/parallel tools/mbcoupler tools/mbcslam
iulian at mcs.anl.gov
Wed Oct 31 11:13:51 CDT 2012
Author: iulian
Date: 2012-10-31 11:13:51 -0500 (Wed, 31 Oct 2012)
New Revision: 5843
Modified:
MOAB/trunk/src/lotte/findpt.c
MOAB/trunk/src/moab/point_locater/lotte/extrafindpt.h
MOAB/trunk/test/parallel/ucdtrvpart.cpp
MOAB/trunk/tools/mbcoupler/ElemUtil.cpp
MOAB/trunk/tools/mbcoupler/ElemUtil.hpp
MOAB/trunk/tools/mbcoupler/ElementTest.cpp
MOAB/trunk/tools/mbcslam/IntxUtils.cpp
MOAB/trunk/tools/mbcslam/IntxUtils.hpp
Log:
compute gl points for a spectral quad
add a test in ElementTest in mbcoupler
add some utilities in mbcslam, not tested yet, to convert to/from spherical
coordinates
Modified: MOAB/trunk/src/lotte/findpt.c
--- MOAB/trunk/src/lotte/findpt.c 2012-10-30 16:52:27 UTC (rev 5842)
+++ MOAB/trunk/src/lotte/findpt.c 2012-10-31 16:13:51 UTC (rev 5843)
@@ -1580,34 +1580,8 @@
#undef DIAGNOSTICS
- 2 - D
-typedef struct {
- unsigned constraints;
- unsigned de, d1;
- real *x[2], *fd1[2];
-} opt_edge_data_2;
-typedef struct {
- real x[2], jac[4];
-} opt_point_data_2;
-typedef struct {
- lagrange_data *ld;
- unsigned size[3];
- const real *elx[2];
- opt_edge_data_2 ed;
- opt_point_data_2 pd;
- real *work;
-} opt_data_2;
-static void opt_alloc_2(opt_data_2 *p, lagrange_data *ld)
+void opt_alloc_2(opt_data_2 *p, lagrange_data *ld)
const unsigned nr = ld[0].n, ns = ld[1].n,
ne = umax_2(nr,ns),
@@ -1623,7 +1597,7 @@
p->ed.fd1[1] = p->ed.fd1[0] + ne;
-static void opt_free_2(opt_data_2 *p)
+void opt_free_2(opt_data_2 *p)
free(p->work);
@@ -1758,7 +1732,7 @@
