[MOAB-dev] r5841 - in MOAB/trunk: src/io tools/mbcoupler
Iulian Grindeanu
iulian at mcs.anl.gov
Tue Oct 30 10:59:51 CDT 2012
Hi Tim,
How was Boulder trip?
I think that this portion of the code assumes that NP=4 (so, the spectral order is 3)
// read connectivity into that space
if (!spectral_mesh)
std::copy(&tmp_conn[start_idx], &tmp_conn[start_idx+4*num_fine_quads], conn_arr);
else {
const unsigned int permute_array[] =
{0, 25, 34, 11, // corner nodes
1, 13, 26, 30, 22, 23, 8, 4, // edge nodes
15, 17, 18, 19 // interior nodes
int f = start_idx;
for (int c = 0; c < num_coarse_quads; c++) {
for (int i = 0; i < verts_per_quad; i++)
conn_arr[i] = tmp_conn[f+permute_array[i]];
f += 4*spectral_unit;
conn_arr += verts_per_quad;
conn_arr -= 4*spectral_unit*num_coarse_quads;
I think they use 4 most of the time, but should it be more general or not?
So should I work with coarse or fine grid, for ACES4BGC ?
Iulian
----- Original Message -----
| Author: tautges
| Date: 2012-10-30 10:20:17 -0500 (Tue, 30 Oct 2012)
| New Revision: 5841
| Modified:
| MOAB/trunk/src/io/ReadNC.cpp
| MOAB/trunk/src/io/ReadNC.hpp
| MOAB/trunk/tools/mbcoupler/Coupler.cpp
| MOAB/trunk/tools/mbcoupler/Coupler.hpp
| Log:
| Backing up some changes in ReadNC towards an option to create coarse,
| true spectral elements, instead of fine linear hexes from a spectral
| mesh.
| In Coupler, some fixes for locate_points that I'd made some time back
| but
| hadn't committed.
| Passes make check, serial and parallel.
| Modified: MOAB/trunk/src/io/ReadNC.cpp
| --- MOAB/trunk/src/io/ReadNC.cpp 2012-10-30 05:50:06 UTC (rev 5840)
| +++ MOAB/trunk/src/io/ReadNC.cpp 2012-10-30 15:20:17 UTC (rev 5841)
| @@ -34,8 +34,9 @@
| ReadNC::ReadNC(Interface* impl) :
| mbImpl(impl), CPU_WORD_SIZE(-1), IO_WORD_SIZE(-1), fileId(-1),
| tMin(-1), tMax(-1), iDim(-1), jDim(-1), tDim(-1), iCDim(-1),
| - jCDim(-1), numUnLim(-1), mCurrentMeshHandle(0), startVertex(0),
| startElem(0), mGlobalIdTag(0), max_line_length(-1),
| - max_str_length(-1), vertexOffset(0), dbgOut(stderr),
| isParallel(false), partMethod(-1), ucdMesh(false), npMesh(false)
| + jCDim(-1), numUnLim(-1), mCurrentMeshHandle(0), startVertex(0),
| + max_str_length(-1), vertexOffset(0), dbgOut(stderr),
| isParallel(false), partMethod(-1), camType(NOT_CAM), isCf(false),
| + spectralOrder(-1), npMesh(false)
| #ifdef USE_MPI
| , myPcomm(NULL)
| @@ -80,8 +81,6 @@
| dbgOut = stderr;
| mCurrentMeshHandle = 0;
| vertexOffset = 0;
| - ucdMesh = false;
| - npMesh = false;
| #ifdef USE_MPI
| myPcomm = NULL;
| @@ -112,9 +111,9 @@
| return rval;
| - bool nomesh = false, novars = false;
| + bool nomesh = false, novars = false, spectral_mesh = false;
| std::string partition_tag_name;
| - rval = parse_options(opts, var_names, tstep_nums, tstep_vals,
| nomesh, novars, partition_tag_name);
| + rval = parse_options(opts, var_names, tstep_nums, tstep_vals,
| nomesh, novars, spectral_mesh, partition_tag_name);
| ERRORR(rval, "Trouble parsing option string.");
| // Open the file
| @@ -155,27 +154,6 @@
| rval = read_header();
| ERRORR(rval, " ");
| - // check if CF convention is being followed
| - std::string attname;
| - std::map<std::string, AttData>::iterator attIt =
| globalAtts.find("conventions");
| - if (attIt == globalAtts.end()) {
| - attIt = globalAtts.find("Conventions");
| - attname = std::string("Conventions");
| - else
| - attname = std::string("conventions");
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20121030/bf5fbbfb/attachment.html>
