[MOAB-dev] r5839 - MOAB/trunk/test/parallel
    vijaysm at mcs.anl.gov
    Mon Oct 29 21:11:58 CDT 2012
Author: vijaysm
Date: 2012-10-29 21:11:58 -0500 (Mon, 29 Oct 2012)
New Revision: 5839
Modified:
   MOAB/trunk/test/parallel/Makefile.am
Log:
Removing a warning. test/parallel/Makefile.am:17: ':='-style assignments are not portable. Autoreconf version 2.61.
Modified: MOAB/trunk/test/parallel/Makefile.am
--- MOAB/trunk/test/parallel/Makefile.am	2012-10-29 04:37:18 UTC (rev 5838)
+++ MOAB/trunk/test/parallel/Makefile.am	2012-10-30 02:11:58 UTC (rev 5839)
@@ -14,7 +14,7 @@
 # Run parallel tests in parallel
 if USE_MPIEXEC
-  OLD_ENVIRONMENT := ${TESTS_ENVIRONMENT}
+  OLD_ENVIRONMENT = ${TESTS_ENVIRONMENT}
   TESTS_ENVIRONMENT = ${MPIEXEC} ${MPIEXEC_NP} ${NP} ${OLD_ENVIRONMENT}
 endif
