[MOAB-dev] Configure error with README.moabuse
Iulian Grindeanu iulian at mcs.anl.gov
Mon Oct 22 16:23:34 CDT 2012
a make clean should fix your issues (or distclean?)
there are no references now to moabuse , except the folder itself + files, which should be fine
----- Original Message -----
| > OK, I just removed all references to moabuse from configure.ac. So
| > if you
| > pull and run autoconf again, things should be ok.
| I just did but the error persists. I'm at -r5820.
| You did not update the configure script to remove references to
| moabuse and hence it still fails. You will have to update config_files
| in config.status and any other references to these files in the
| configure script. Also, you can add the header and sources to the
| installation by adding them part of AM_INSTALL or some other variable.
| So please revert the *.in for sources.
| Autotools is a small learning curve. These are easy mistakes to fix
| and so no worries.
| Best,
| Vijay
| On Mon, Oct 22, 2012 at 4:12 PM, Milad Fatenejad <icksa1 at gmail.com>
| wrote:
| > Hi Vijay:
| > if you
| > So, the idea was that these files would get copied into the install
| > directory. I spoke to Iulian today and realized that I kind of
| > screwed this
| > up. The way it is set up now, the files will get copied into the
| > build
| > directory. You are correct that the write thing to do is create a
| > Makefile.am and work with that. I am new to autoconf and made a lot
| > of
| > mistakes, so my hope is to just disable all of this until I can
| > learn more.
| > My apologies.
| > Milad
| > On Mon, Oct 22, 2012 at 3:51 PM, Vijay S. Mahadevan
| > <vijay.m at gmail.com>
| > wrote:
| >> Milad,
| >> I still get the same configure error after pulling your latest
| >> changes. I now have a README.moabuse.in but looks like you need to
| >> update configure or add Makefile.am for the changes to take effect.
| >> config.status: error: cannot find input file:
| >> examples/moabuse/README.moabuse
| >> [vijaysm at janus moab-dev] ls examples/moabuse/
| >> Makefile Makefile.in mberr.hpp.in moabuse1.cpp.in moabuse2.cpp.in
| >> moabuse3.cpp.in moabuse4.cpp.in README.moabuse.in
| >> As Iulian pointed out, why are these configure time files anyway
| >> and
| >> not just sources that get compiled during make ? The hpp/cpp files
| >> dont need to be inspected during configure and it is unnecessary.
| >> Vijay
| >> On Mon, Oct 22, 2012 at 2:52 PM, Milad Fatenejad <icksa1 at gmail.com>
| >> wrote:
| >> > Hi Vijay:
| >> > Sorry, this was my fault. I just checked in a fix.
| >> > Milad
| >> > On Mon, Oct 22, 2012 at 2:37 PM, Vijay S. Mahadevan
| >> > wrote:
| >> >> While updating the repository to the latest version, I pulled
| >> >> and
| >> >> re-configured with the command below but the configure process
| >> >> gives
| >> >> an error message now and stops.
| >> >> ./configure --prefix=/home/vijaysm/software/opt/moab
| >> >> --with-hdf5=/home/jain/hdf5-1.8.9 --disable-debug
| >> >> --enable-optimize
| >> >> --with-mpi=/soft/mvapich2/1.5.1p1/intel/11.1.059
| >> >> --enable-mbcoupler
| >> >> --enable-mbpart --enable-mbsize
| >> >> --with-netcdf=/home/jain/lib/netcdf-4.1.2
| >> >> --with-zoltan=/home/jain/lib/Zoltan_v3.3
| >> >> --with-parmetis=/home/jain/ParMETIS3_1
| >> >> checking build system type... x86_64-unknown-linux-gnu
| >> >> config.status: creating examples/moabuse/Makefile
| >> >> config.status: creating examples/moabuse/README.moabuse
| >> >> When I do an svn up again, I get
| >> >> Restored 'examples/moabuse/README.moabuse'.
| >> >> Perhaps somewhere inside configure, the README file is being
| >> >> deleted
| >> >> (I checked Makefile.in and it is part of the Clean files). Also
| >> >> I dont
| >> >> understand the logic for adding a README file as part of the
| >> >> configure
| >> >> process. This seems to be static and a reconfigure wipes it out.
| >> >> Is
| >> >> there a README.moabuse.in that is not in the repository ? Let me
| >> >> know
| >> >> if you need config.log for more details.
| >> >> Thanks,
| >> >> Vijay
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20121022/c59c2be5/attachment.html>
