[MOAB-dev] adding 'read and broadcast' to HDF5 reader
Iulian Grindeanu
iulian at mcs.anl.gov
Fri Oct 19 15:26:46 CDT 2012
And of course I am wrong.
There is this ParallelComm object/class that can be used to identify what proc we are on, in ReadHDF5.cpp
----- Original Message -----
| Hello Rob,
| I think that change has to happen in src/parallel/ReadParallel.cpp
| I am not sure yet though, Tim would confirm that
| Iulian
| | Tim knows all this but for the rest of the list, here's the short
| | story:
| | MOAB's HDF5 reader and writer have a problem on BlueGene where it
| | will
| | collectively read in initial conditions or write output, and run out
| | of memory. This out-of-memory condition comes from MOAB doing all
| | the
| | right things -- using HDF5, using collective I/O -- but the MPI-IO
| | library on Intrepid goes and consumes too much memory.
| | I've got one approach to deal with the MPI-IO memory issue for
| | writes.
| | This approach would sort of work for the reads, but what is really
| | needed is for rank 0 to do the read and broadcast the result to
| | everyone.
| | So, I'm looking for a little help understanding MOAB's read side of
| | the code. Conceptually, all processes read the table of entities.
| | A fairly small 'mbconvert' job will run out of memory:
| | 512 nodes, 2048 processors:
| | NODES=512
| | CORES=$(($NODES * 4))
| | cd /intrepid-fs0/users/robl/scratch/moab-test
| | cqsub -t 15 -m vn -p SSSPP -e MPIRUN_LABEL=1:BG_COREDUMPONEXIT=1 \
| | -n $NODES -c $CORES /home/robl/src/moab-svn/build/tools/mbconvert\
| | -O CPUTIME -O PARALLEL_GHOSTS=3.0.1 -O PARALLEL=READ_PART \
| | -O PARALLEL_RESOLVE_SHARED_ENTS -O PARTITION -t \
| | -o CPUTIME -o PARALLEL=WRITE_PART
| | /intrepid-fs0/users/tautges/persistent/meshes/2bricks/nogeom/64bricks_8mtet_ng_rib_${CORES}.h5m
| | /intrepid-fs0/users/robl/scratch/moab/8mtet_ng-${CORES}-out.h5m
| | I'm kind of stumbling around ReadHDF5::load_file and
| | ReadHDF5::load_file_partial trying to find a spot where a collection
| | of tags are read into memory. I'd like to, instead of having all
| | processors do the read, have just one processor read and then send
| | the
| | tag data to the other processors.
| | First, do I remember the basic MOAB concept correctly: that early on
| | every process reads the exact same tables out of the (in this case
| | HDF5) file?
| | If I want rank 0 to do all the work and send data to other ranks,
| | where's the best place to slip that in? It's been a while since I
| | did
| | anything non-trivial in C++, so some of these data structures are
| | kind
| | of greek to me.
| | thanks
| | ==rob
| | Rob Latham
| | Mathematics and Computer Science Division
| | Argonne National Lab, IL USA
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20121019/af5749af/attachment.html>
