[MOAB-dev] r5810 - in MOAB/trunk/src: . io
    tautges at mcs.anl.gov
    Fri Oct 19 09:14:05 CDT 2012
Author: tautges
Date: 2012-10-19 09:14:05 -0500 (Fri, 19 Oct 2012)
New Revision: 5810
Modified:
   MOAB/trunk/src/Makefile.am
   MOAB/trunk/src/io/WriteVtk.hpp
Log:
- Removing extraneous whitespace from Makefile.am that was warned about.
- Adding default argument for WriteVtk::write_file.
Modified: MOAB/trunk/src/Makefile.am
--- MOAB/trunk/src/Makefile.am	2012-10-19 13:32:34 UTC (rev 5809)
+++ MOAB/trunk/src/Makefile.am	2012-10-19 14:14:05 UTC (rev 5810)
@@ -75,8 +75,8 @@
   OrientedBox.cpp \
   OrientedBox.hpp \
   OrientedBoxTreeTool.cpp \
-  moab/point_locater/lotte/minmax.h \
-  moab/point_locater/lotte/extrafindpt.h \
+  moab/point_locater/lotte/minmax.h \
+  moab/point_locater/lotte/extrafindpt.h \
   lotte/poly.c \
   moab/point_locater/lotte/poly.h \
   lotte/findpt.c \
Modified: MOAB/trunk/src/io/WriteVtk.hpp
--- MOAB/trunk/src/io/WriteVtk.hpp	2012-10-19 13:32:34 UTC (rev 5809)
+++ MOAB/trunk/src/io/WriteVtk.hpp	2012-10-19 14:14:05 UTC (rev 5810)
@@ -49,7 +49,7 @@
                          const std::vector<std::string>& qa_list,
                          const Tag* tag_list,
                          int num_tags,
-                         int export_dimension);
+                         int export_dimension = 0);
 private:
