[MOAB-dev] r5808 - MOAB/trunk/test/perf
tautges at mcs.anl.gov
Thu Oct 18 14:53:44 CDT 2012
Author: tautges
Date: 2012-10-18 14:53:44 -0500 (Thu, 18 Oct 2012)
New Revision: 5808
Modified:
MOAB/trunk/test/perf/perf.cpp
MOAB/trunk/test/perf/runtest
MOAB/trunk/test/perf/tstt_perf_binding.cpp
Log:
More changes to test timing of direct interfaces to tags/connectivity/etc.
Passes make check parallel, optimized, debug.
Modified: MOAB/trunk/test/perf/perf.cpp
--- MOAB/trunk/test/perf/perf.cpp 2012-10-18 15:54:09 UTC (rev 5807)
+++ MOAB/trunk/test/perf/perf.cpp 2012-10-18 19:53:44 UTC (rev 5808)
@@ -52,11 +52,19 @@
void testB(const int nelem, const double *coords, int *connect);
void testC(const int nelem, const double *coords);
void testD(const int nelem, const double *coords);
+void testE(const int nelem, const double *coords, int *connect);
void print_time(const bool print_em, double &tot_time, double &utime, double &stime, long &imem, long &rmem);
void query_vert_to_elem();
void query_elem_to_vert();
void query_struct_elem_to_vert();
+void query_elem_to_vert_direct();
+void query_vert_to_elem_direct();
+ErrorCode normalize_elems(double *coords);
+void check_answers(const char *);
+#define RC(msg) if (MB_SUCCESS != result) do {std::cout << "FAIL in " << msg << std::endl;return;} while (true)
+#define RR(msg) if (MB_SUCCESS != result) do {std::cout << "FAIL in " << msg << std::endl;return result;} while (true)
void compute_edge(double *start, const int nelem, const double xint,
const int stride)
@@ -242,8 +250,8 @@
#endif
print_time(false, ttime1, utime1, stime1, imem, rmem);
- std::cout << "MOAB: TFI time = " << ttime1-ttime0 << " sec"
- << std::endl;
+// std::cout << "MOAB: TFI time = " << ttime1-ttime0 << " sec"
+// << std::endl;
void build_connect(const int nelem, const EntityHandle vstart, int *&connect)
@@ -275,11 +283,25 @@
Interface *gMB;
+Tag pos_tag, pos2_tag;
+void init()
+ gMB = new Core();
+ double def_val[3] = {0.0, 0.0, 0.0};
+ ErrorCode rval = gMB->tag_get_handle("position_tag", 3, MB_TYPE_DOUBLE, pos_tag,
+ MB_TAG_DENSE | MB_TAG_CREAT, def_val);
+ assert(MB_SUCCESS == rval);
+ rval = gMB->tag_get_handle("position2_tag", 3, MB_TYPE_DOUBLE, pos2_tag,
