[MOAB-dev] r5799 - in MOAB/trunk: src/io src/parallel src/parallel/moab test/parallel
iulian at mcs.anl.gov
Tue Oct 16 01:17:49 CDT 2012
Author: iulian
Date: 2012-10-16 01:17:49 -0500 (Tue, 16 Oct 2012)
New Revision: 5799
Added:
MOAB/trunk/test/parallel/ucdnodpart.cpp
Modified:
MOAB/trunk/src/io/ReadNC.cpp
MOAB/trunk/src/parallel/ParallelComm.cpp
MOAB/trunk/src/parallel/moab/ParallelComm.hpp
MOAB/trunk/test/parallel/Makefile.am
Log:
progress on nodal partition; mesh generation part
Modified: MOAB/trunk/src/io/ReadNC.cpp
--- MOAB/trunk/src/io/ReadNC.cpp 2012-10-15 16:49:47 UTC (rev 5798)
+++ MOAB/trunk/src/io/ReadNC.cpp 2012-10-16 06:17:49 UTC (rev 5799)
@@ -254,9 +254,12 @@
// Read variables onto grid
if (!novars) {
- rval = read_variables(tmp_set, var_names, tstep_nums);
- if (MB_FAILURE == rval)
- return rval;
+ if (!npMesh) {
+ rval = read_variables(tmp_set, var_names, tstep_nums);
+ if (MB_FAILURE == rval)
+ return rval;
else {
// read dimension variable by default
@@ -768,7 +771,7 @@
return MB_SUCCESS;
-// a function to decide the owning proc for a global id (value from 1 to iN), in a trivial partition space
+// a function to decide the owning proc for a global id (value from 1 to iN), in a nodal partition space
// will also return the index on the owning proc (so we can determine the handle)
int owning_processor(int iN, int ip, int gid, int & oIndexOnOwningProc)
@@ -955,7 +958,7 @@
num_local_verts++;
local_gid.insert(k+1);// this could have nodes with higher gid than the local owned range
- if (k+1<start_gid || k+1 > end_gid)// k+1 < start_gid cannot really happen !
+ if (k+1<start_gid || k+1 > end_gid)// k+1 < start_gid cannot really happen in our case !
non_owned_gids.insert(k+1);
// local owned range
@@ -1074,7 +1077,7 @@
Range owned_verts(start_vertex, start_vertex+num_owned_nodes-1);
// Range std::vector<int>
- rval = myPcomm->establish_shared_ents(owned_verts, not_owned_verts, processors, remote_handles, not_owned_gids);// these lists are
+ rval = myPcomm->resolve_shared_verts(owned_verts, not_owned_verts, processors, remote_handles, not_owned_gids);// these lists are
// the base for tuples
ERRORR(rval, "Couldn't settle shared entities with other procs.");
Modified: MOAB/trunk/src/parallel/ParallelComm.cpp
--- MOAB/trunk/src/parallel/ParallelComm.cpp 2012-10-15 16:49:47 UTC (rev 5798)
