[MOAB-dev] r5779 - in MOAB/trunk: src/io src/parallel	src/parallel/moab test/io test/parallel
    iulian at mcs.anl.gov
    Tue Oct  9 16:50:12 CDT 2012
Author: iulian
Date: 2012-10-09 16:50:12 -0500 (Tue, 09 Oct 2012)
New Revision: 5779
Added:
   MOAB/trunk/test/parallel/ucdtrvpart.cpp
Modified:
   MOAB/trunk/src/io/ReadNC.cpp
   MOAB/trunk/src/io/ReadNC.hpp
   MOAB/trunk/src/parallel/ParallelComm.cpp
   MOAB/trunk/src/parallel/gs.cpp
   MOAB/trunk/src/parallel/moab/ParallelComm.hpp
   MOAB/trunk/test/io/read_ucd_nc.cpp
   MOAB/trunk/test/parallel/Makefile.am
Log:
first crack at nodal partition for homme reader.
It is not ready yet, nothing else should be affected
it passes tests in serial and parallel
Also, introduce a test for trivial partition; right now, it is just
testing the number of nodes owned by each processor, but it should also test
some tag values.
one more change: the option to read using trivial partition should be passed
as  "PARTITION_METHOD=TRIVIAL_PARTITION"
before, it was simply "TRIVIAL_PARTITION"
Modified: MOAB/trunk/src/io/ReadNC.cpp
--- MOAB/trunk/src/io/ReadNC.cpp	2012-10-09 18:38:45 UTC (rev 5778)
+++ MOAB/trunk/src/io/ReadNC.cpp	2012-10-09 21:50:12 UTC (rev 5779)
@@ -35,7 +35,7 @@
 ReadNC::ReadNC(Interface* impl) :
   mbImpl(impl), CPU_WORD_SIZE(-1), IO_WORD_SIZE(-1), fileId(-1), tMin(-1), tMax(-1), iDim(-1), jDim(-1), tDim(-1), iCDim(-1),
       jCDim(-1), numUnLim(-1), mCurrentMeshHandle(0), startVertex(0), startElem(0), mGlobalIdTag(0), max_line_length(-1),
-      max_str_length(-1), vertexOffset(0), dbgOut(stderr), isParallel(false), partMethod(-1), ucdMesh(false)
+      max_str_length(-1), vertexOffset(0), dbgOut(stderr), isParallel(false), partMethod(-1), ucdMesh(false), npMesh(false)
 #ifdef USE_MPI
 , myPcomm(NULL)
@@ -81,6 +81,7 @@
   mCurrentMeshHandle = 0;
   vertexOffset = 0;
   ucdMesh = false;
+  npMesh = false;
 #ifdef USE_MPI
   myPcomm = NULL;
@@ -217,6 +218,10 @@
       rval = init_HOMMEucd_vals(opts);
       if (MB_SUCCESS == rval) {
         ucdMesh = true;
+        if (opts.match_option("PARTITION_METHOD", "NODAL_PARTITION") == MB_SUCCESS)
+          npMesh=true;
     // else if dimension names "lon" and "lat' exist then it's the Eulerian Spectral grid
@@ -238,11 +243,13 @@
     ERRORR(rval, "Mesh characteristics didn't match from last read.\n");
   else if (!nomesh) {
-    if (ucdMesh)
+    if (npMesh)
+      rval = create_np_verts_quads(opts, tmp_set, quads);
+    else if (ucdMesh)
       rval = create_ucd_verts_quads(opts, tmp_set, quads);
     else
       rval = create_verts_quads(scdi, tmp_set, quads);
-    ERRORR(rval, "Trouble creating vertices.");
+    ERRORR(rval, "Trouble creating vertices and quads.");
   // Read variables onto grid
@@ -277,12 +284,15 @@
     if (ucdMesh && !novars)
