[MOAB-dev] Moab Paraview plugin will not compile
    Cook, Rich
    cook47 at llnl.gov
    Mon Oct  8 16:11:09 CDT 2012
OK, got it.
I am a bit curious about why it's complaining about /tmp/dpkg-mkdeb.eHKBP8GXWA/src/ParaView-3.14.0-Source/ParaViewUse.cmake, when I put -DParaView_DIR=/nfs/tmp2/rcook/ParaView/moab-plugin/Paraview-BuildDir/src/ParaView-3.14.0-Build/ -- the /tmp/ directory was something I did use before and somehow it remembered it...
On Oct 8, 2012, at 11:56 AM, Tim Tautges wrote:
> The paraview plugin is a work in progress.  It's been updated in the trunk, but it's still not working, or needs the latest repo version of paraview rather than a released version.  I'm hoping we get that working in the next few weeks, so feel free to check back (or keep an eye on commit messages, probably from either me or Bob O'Bara).
> - tim
>> + cmake -DParaView_DIR=/nfs/tmp2/rcook/ParaView/moab-plugin/Paraview-BuildDir/src/ParaView-3.14.0-Build/ .
>> -- The C compiler identification is GNU
>> -- The CXX compiler identification is GNU
>> -- Check for working C compiler: /usr/local/bin/gcc
>> -- Check for working C compiler: /usr/local/bin/gcc -- works
>> -- Detecting C compiler ABI info
>> -- Detecting C compiler ABI info - done
>> -- Check for working CXX compiler: /usr/bin/c++
>> -- Check for working CXX compiler: /usr/bin/c++ -- works
>> -- Detecting CXX compiler ABI info
>> -- Detecting CXX compiler ABI info - done
>> CMake Error at CMakeLists.txt:8 (INCLUDE):
>>   include could not find load file:
>> CMake Error at CMakeLists.txt:9 (ADD_PARAVIEW_PLUGIN):
>>   Unknown CMake command "ADD_PARAVIEW_PLUGIN".
>> -- Configuring incomplete, errors occurred!
> "You will keep in perfect peace him whose mind is
>  steadfast, because he trusts in you."               Isaiah 26:3
>             Tim Tautges            Argonne National Laboratory
>         (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
> phone (gvoice): (608) 354-1459      1500 Engineering Dr.
>            fax: (608) 263-4499      Madison, WI 53706
✐Richard Cook
✇ Lawrence Livermore National Laboratory
Bldg-453 Rm-4024, Mail Stop L-557
7000 East Avenue,  Livermore, CA, 94550, USA
☎ (office) (925) 423-9605
☎ (fax) (925) 423-6961
Information Management & Graphics Grp., Services & Development Div., Integrated Computing & Communications Dept.
(opinions expressed herein are mine and not those of LLNL)
