[MOAB-dev] r5758 - MOAB/trunk/src/io
iulian at mcs.anl.gov iulian at mcs.anl.gov
Thu Sep 27 15:29:19 CDT 2012
Author: iulian
Date: 2012-09-27 15:29:19 -0500 (Thu, 27 Sep 2012)
New Revision: 5758
Modified:
   MOAB/trunk/src/io/ReadNC.cpp
   MOAB/trunk/src/io/ReadNC.hpp
Log:
correct reading data in parallel for Homme grids, considering the
local range of the global id, for vertices.
Still, it does not work yet in parallel.
Also, reformat the code, I could not read it, it had lots of tabs
(so replace tabs with 2 spaces, and indentation is now at 2 spaces)
Modified: MOAB/trunk/src/io/ReadNC.cpp
--- MOAB/trunk/src/io/ReadNC.cpp	2012-09-27 16:41:29 UTC (rev 5757)
+++ MOAB/trunk/src/io/ReadNC.cpp	2012-09-27 20:29:19 UTC (rev 5758)
@@ -22,26 +22,23 @@
 #define ERRORR(rval, str) \
     if (MB_SUCCESS != rval) {readMeshIface->report_error("%s", str); return rval;}
 #define ERRORS(err, str) \
     if (err) {readMeshIface->report_error("%s", str); return MB_FAILURE;}
 namespace moab {
-ReaderIface* ReadNC::factory( Interface* iface )
-  { return new ReadNC( iface ); }
+ReaderIface* ReadNC::factory(Interface* iface) {
+  return new ReadNC(iface);
-ReadNC::ReadNC(Interface* impl)
-        : mbImpl(impl), CPU_WORD_SIZE(-1), IO_WORD_SIZE(-1), fileId(-1),
-          tMin(-1), tMax(-1),
-	  iDim(-1), jDim(-1), tDim(-1), iCDim(-1), jCDim(-1),
-	  numUnLim(-1), mCurrentMeshHandle(0),
-          startVertex(0), startElem(0), mGlobalIdTag(0),
-          max_line_length(-1), max_str_length(-1), vertexOffset(0), dbgOut(stderr),
-          isParallel(false), partMethod(-1), ucdMesh(false)
+ReadNC::ReadNC(Interface* impl) :
+  mbImpl(impl), CPU_WORD_SIZE(-1), IO_WORD_SIZE(-1), fileId(-1), tMin(-1), tMax(-1), iDim(-1), jDim(-1), tDim(-1), iCDim(-1),
+      jCDim(-1), numUnLim(-1), mCurrentMeshHandle(0), startVertex(0), startElem(0), mGlobalIdTag(0), max_line_length(-1),
+      max_str_length(-1), vertexOffset(0), dbgOut(stderr), isParallel(false), partMethod(-1), ucdMesh(false)
 #ifdef USE_MPI
-        , myPcomm(NULL)
+, myPcomm(NULL)
 #endif
   assert(impl != NULL);
@@ -52,15 +49,14 @@
     gCDims[i] = -1;
     lCDims[i] = -1;
   locallyPeriodic[0] = locallyPeriodic[1] = 0;
   globallyPeriodic[0] = globallyPeriodic[1] = 0;
