[MOAB-dev] r5733 - in MOAB/trunk: src/parallel src/parallel/moab test/parallel tools/dagmc
Tim Tautges tautges at mcs.anl.gov
Wed Sep 12 16:58:35 CDT 2012
Thanks Xiabing.
- tim
On 09/12/2012 03:25 PM, xbxu at mcs.anl.gov wrote:
> Author: xbxu
> Date: 2012-09-12 15:25:34 -0500 (Wed, 12 Sep 2012)
> New Revision: 5733
> Modified:
>     MOAB/trunk/src/parallel/ParallelMergeMesh.cpp
>     MOAB/trunk/src/parallel/TupleList.cpp
>     MOAB/trunk/src/parallel/gs.cpp
>     MOAB/trunk/src/parallel/moab/TupleList.hpp
>     MOAB/trunk/src/parallel/moab/gs.hpp
>     MOAB/trunk/test/parallel/parallel_hdf5_test.cc
>     MOAB/trunk/tools/dagmc/test_geom.cc
> Log:
> o change type name real to realType which is complained by pgi
> compiler;
> o update test_geom test to use a bigger epsilon number, the result
> computed by pgi compiler is bigger than the old epsilon number which
> will fail the test.
> o now make check will pass when using pgi compiler.
> Modified: MOAB/trunk/src/parallel/ParallelMergeMesh.cpp
> --- MOAB/trunk/src/parallel/ParallelMergeMesh.cpp	2012-09-10 16:48:00 UTC (rev 5732)
> +++ MOAB/trunk/src/parallel/ParallelMergeMesh.cpp	2012-09-12 20:25:34 UTC (rev 5733)
> @@ -655,7 +655,7 @@
>       a_val = a*mr;
>       b_val = b*mr;
>       for(unsigned long i=0; i< mr;i++){
> -      real t =tup.vr_rd[a_val];
> +      realType t =tup.vr_rd[a_val];
>         tup.vr_wr[a_val] = tup.vr_rd[b_val];
>         tup.vr_wr[b_val] = t;
>         a_val++;
> Modified: MOAB/trunk/src/parallel/TupleList.cpp
> --- MOAB/trunk/src/parallel/TupleList.cpp	2012-09-10 16:48:00 UTC (rev 5732)
> +++ MOAB/trunk/src/parallel/TupleList.cpp	2012-09-12 20:25:34 UTC (rev 5733)
> @@ -116,11 +116,11 @@
>       } else
>         vul = NULL;
>       if (max*mr > 0) {
> -      size = max*mr*sizeof(real);
> +      size = max*mr*sizeof(realType);
>         void *resr = malloc(size);
>         if(!resr && max*ml > 0)
>   	fail("%s: allocation of %d bytes failed\n",__FILE__,(int)size);
> -      vr=(real*) resr;
> +      vr=(realType*) resr;
>       } else
>         vr = NULL;
> @@ -165,13 +165,13 @@
>         vul = (ulong*) resu;
>       if (vr || (max*mr > 0)){
>         void *resr = realloc(vr, size);
>         if(!resr && max*mr > 0){
>   	return moab::MB_MEMORY_ALLOCATION_FAILED;
> -      vr = (real*) resr;
> +      vr = (realType*) resr;
>       //Set read variables
> @@ -295,7 +295,7 @@
>       return -1;	// If the value wasn't present or an invalid key was given
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
