[MOAB-dev] r5730 - MOAB/trunk/examples
iulian at mcs.anl.gov
Mon Sep 10 10:45:47 CDT 2012
Author: iulian
Date: 2012-09-10 10:45:47 -0500 (Mon, 10 Sep 2012)
New Revision: 5730
Modified:
MOAB/trunk/examples/IntxMeshes.cpp
MOAB/trunk/examples/IntxMeshesOnSphere.cpp
MOAB/trunk/examples/Makefile.am
Log:
forgot to commit the makefile for the new example with intersection of quad
meshes on the sphere
Modified: MOAB/trunk/examples/IntxMeshes.cpp
--- MOAB/trunk/examples/IntxMeshes.cpp 2012-09-07 23:19:27 UTC (rev 5729)
+++ MOAB/trunk/examples/IntxMeshes.cpp 2012-09-10 15:45:47 UTC (rev 5730)
@@ -62,7 +62,7 @@
Tag redParentTag;
Tag blueParentTag;
-int dbg_1 = 0;
+int dbg_1 = 1;
ofstream mout_1;// some debug file
double epsilon_1 = 1.e-5; // cm, for coincident points in P, the intersection area
@@ -789,7 +789,14 @@
if (nP > 1) // this will also construct triangles in the new mesh, if needed
findNodes(redT, currentBlue, P, nP);
+ else
+ if (dbg_1)
+ std::cout << " redT and currentBlue do not intersect " << mb->id_from_handle(redT)
+ <<" "<< mb->id_from_handle(currentBlue) << "\n";
EntityHandle blueNeighbors[3];
Modified: MOAB/trunk/examples/IntxMeshesOnSphere.cpp
--- MOAB/trunk/examples/IntxMeshesOnSphere.cpp 2012-09-07 23:19:27 UTC (rev 5729)
+++ MOAB/trunk/examples/IntxMeshesOnSphere.cpp 2012-09-10 15:45:47 UTC (rev 5730)
@@ -56,6 +56,7 @@
// these will be on the out mesh
Tag redParentTag;
Tag blueParentTag;
+Tag countTag;
// some vars for current process
// after intersection, these var are still needed by findNodes, to establish the
@@ -118,6 +119,9 @@
rval = mb->tag_get_handle("Negative", 1, MB_TYPE_INTEGER, blueParentTag,
MB_TAG_SPARSE | MB_TAG_CREAT, &defaultInt);
+ rval = mb->tag_get_handle("Counting", 1, MB_TYPE_INTEGER, countTag,
+ MB_TAG_SPARSE | MB_TAG_CREAT, &defaultInt);
return;
// vec utils
