[MOAB-dev] r5717 - MOAB/trunk/src/moab/point_locater/element_maps
rhl6856 at mcs.anl.gov
Wed Aug 29 14:31:56 CDT 2012
Author: rhl6856
Date: 2012-08-29 14:31:55 -0500 (Wed, 29 Aug 2012)
New Revision: 5717
Modified:
MOAB/trunk/src/moab/point_locater/element_maps/linear_hex_map.hpp
MOAB/trunk/src/moab/point_locater/element_maps/linear_tet_map.hpp
MOAB/trunk/src/moab/point_locater/element_maps/quadratic_hex_map.hpp
MOAB/trunk/src/moab/point_locater/element_maps/spectral_hex_map.hpp
Log:
scalar fields
Modified: MOAB/trunk/src/moab/point_locater/element_maps/linear_hex_map.hpp
--- MOAB/trunk/src/moab/point_locater/element_maps/linear_hex_map.hpp 2012-08-29 19:31:55 UTC (rev 5716)
+++ MOAB/trunk/src/moab/point_locater/element_maps/linear_hex_map.hpp 2012-08-29 19:31:55 UTC (rev 5717)
@@ -148,6 +148,46 @@
template< typename Point, typename Points>
+ double evaluate_scalar_field( const Point & p,
+ const Points & field_values) const{
+ double f = 0.0;
+ for(int i = 0; i < 3; ++i){ result[ i] = 0; }
+ for (unsigned i = 0; i < 8; ++i) {
+ const double N_i = (1 + p[0]*reference_points(i,0))
+ * (1 + p[1]*reference_points(i,1))
+ * (1 + p[2]*reference_points(i,2));
+ f += N_i * field_values[ i];
+ f *= 0.125;
+ return f;
+ template< typename Points>
+ double integrate_scalar_field(Points & field_values) const {
+ typename typename Points::value_type Point;
+ const double gauss[1][2] = { { 2.0, 0.0 } };
+ const std::size_t gauss_count = 1;
+ double I(0.0);
+ for(std::size_t j1 = 0; j1 < gauss_count; ++j1) {
+ double x1 = gauss[j1][1];
+ double w1 = gauss[j1][0];
+ for(std::size_t j2 = 0; j2 < gauss_count; ++j2) {
+ double x2 = gauss[j2][1];
+ double w2 = gauss[j2][0];
+ for(std::size_t j3 = 0; j3 < gauss_count; ++j3) {
+ double x3 = gauss[j3][1];
+ double w3 = gauss[j3][0];
+ Point x(x1,x2,x3);
+ Matrix J;
+ jacobian( x, field_values, J);
+ I += evaluate_scalar_field(x,field_values)*w1*w2*w3*J.determinant();
+ return I;
+ template< typename Point, typename Points>
Matrix& jacobian( const Point & p, const Points & points, Matrix & J) const{
J = Matrix(0.0);
for (std::size_t i = 0; i < 8; ++i) {
