[MOAB-dev] r5708 - MOAB/trunk/src/io
tautges at mcs.anl.gov
Mon Aug 27 17:13:48 CDT 2012
Author: tautges
Date: 2012-08-27 17:13:48 -0500 (Mon, 27 Aug 2012)
New Revision: 5708
Modified:
MOAB/trunk/src/io/DamselUtil.cpp
MOAB/trunk/src/io/DamselUtil.hpp
MOAB/trunk/src/io/ReadDamsel.cpp
MOAB/trunk/src/io/ReadDamsel.hpp
MOAB/trunk/src/io/WriteDamsel.cpp
MOAB/trunk/src/io/WriteDamsel.hpp
Log:
More progress on reading/writing Damsel files.
Modified: MOAB/trunk/src/io/DamselUtil.cpp
--- MOAB/trunk/src/io/DamselUtil.cpp 2012-08-23 19:45:27 UTC (rev 5707)
+++ MOAB/trunk/src/io/DamselUtil.cpp 2012-08-27 22:13:48 UTC (rev 5708)
@@ -1,4 +1,5 @@
#include "DamselUtil.hpp"
+#include "moab/Range.hpp"
#include "damsel.h"
@@ -55,4 +56,43 @@
MB_TYPE_OPAQUE // DAMSEL_DATA_TYPE_PREDEFINED_WATERMARK = 9;
+DamselUtil::DamselUtil()
+ : dmslLib(DAMSEL_LIBRARY_INVALID), dmslModel(DAMSEL_MODEL_INVALID),
+ moabHandleType(DAMSEL_HANDLE_TYPE_INVALID)
+ //! convert handles in a container to a range; assumes EntityHandle and Damsel
+ //! entity handles are the same size
+ErrorCode DamselUtil::container_to_range(damsel_model m, damsel_container &c, Range &r)
+ if (DMSLcontainer_get_type(c) == DAMSEL_HANDLE_CONTAINER_TYPE_SEQUENCE) {
+ damsel_handle start;
+ size_t count, stride;
+ damsel_err_t err = DMSLcontainer_sequence_get_contents(m, c, &start, &count, &stride);
+ CHK_DMSL_ERR_NM(err);
+ for (damsel_handle i = start+(count-1)*stride; i >= start; i-=stride)
+ r.insert(i);
+ else if (DMSLcontainer_get_type(c) == DAMSEL_HANDLE_CONTAINER_TYPE_VECTOR) {
+ damsel_handle *handle_ptr;
+ size_t count;
+ damsel_err_t err = DMSLcontainer_vector_get_contents(m, c, &handle_ptr, &count);
+ for (int i = count-1; i >= 0; i--)
+ r.insert(handle_ptr[i]);
+ else if (DMSLcontainer_get_type(c) == DAMSEL_HANDLE_CONTAINER_TYPE_TREE) {
+ damsel_handle_ptr node_ptr = NULL;
+ damsel_container cont = NULL;
+ damsel_err_t err = DMSLcontainer_tree_get_contents(m, c, &node_ptr, &cont);
+ while (err.id == DMSL_OK.id && cont) {
+ ErrorCode rval = container_to_range(m, c, r);
+ if (MB_SUCCESS != rval) return rval;
+ err = DMSLcontainer_tree_get_contents(m, c, &node_ptr, &cont);
+ return MB_SUCCESS;
