[MOAB-dev] r5696 - in MOAB/branches/mcm_kwfixes: itaps/imesh src src/io src/moab src/parallel src/parallel/moab tools/dagmc
mcmiller at mcs.anl.gov
Wed Aug 15 01:53:47 CDT 2012
Author: mcmiller
Date: 2012-08-15 01:53:47 -0500 (Wed, 15 Aug 2012)
New Revision: 5696
Modified:
MOAB/branches/mcm_kwfixes/itaps/imesh/iMeshP_MOAB.cpp
MOAB/branches/mcm_kwfixes/src/BSPTreePoly.cpp
MOAB/branches/mcm_kwfixes/src/Core.cpp
MOAB/branches/mcm_kwfixes/src/FBEngine.cpp
MOAB/branches/mcm_kwfixes/src/HigherOrderFactory.cpp
MOAB/branches/mcm_kwfixes/src/OrientedBoxTreeTool.cpp
MOAB/branches/mcm_kwfixes/src/SequenceData.cpp
MOAB/branches/mcm_kwfixes/src/SmoothFace.cpp
MOAB/branches/mcm_kwfixes/src/VarLenDenseTag.cpp
MOAB/branches/mcm_kwfixes/src/io/FileTokenizer.cpp
MOAB/branches/mcm_kwfixes/src/io/IODebugTrack.cpp
MOAB/branches/mcm_kwfixes/src/io/IODebugTrack.hpp
MOAB/branches/mcm_kwfixes/src/io/ReadSmf.cpp
MOAB/branches/mcm_kwfixes/src/io/ReadTetGen.cpp
MOAB/branches/mcm_kwfixes/src/io/Tqdcfr.cpp
MOAB/branches/mcm_kwfixes/src/io/WriteSTL.cpp
MOAB/branches/mcm_kwfixes/src/moab/ScdInterface.hpp
MOAB/branches/mcm_kwfixes/src/parallel/ParallelComm.cpp
MOAB/branches/mcm_kwfixes/src/parallel/WriteHDF5Parallel.cpp
MOAB/branches/mcm_kwfixes/src/parallel/moab/ParallelComm.hpp
MOAB/branches/mcm_kwfixes/tools/dagmc/obb_analysis.cpp
Log:
some fixes from Klocwork static analysis -- not yet tested
Modified: MOAB/branches/mcm_kwfixes/itaps/imesh/iMeshP_MOAB.cpp
--- MOAB/branches/mcm_kwfixes/itaps/imesh/iMeshP_MOAB.cpp 2012-08-15 02:53:22 UTC (rev 5695)
+++ MOAB/branches/mcm_kwfixes/itaps/imesh/iMeshP_MOAB.cpp 2012-08-15 06:53:47 UTC (rev 5696)
@@ -416,6 +416,8 @@
ErrorCode rval;
ParallelComm* pcomm = PCOMM;
+ if (!pcomm)
+ ERROR (iBase_FAILURE,"No PComm");
ALLOC_CHECK_ARRAY( part_ids, part_handles_size );
for (int i = 0; i < part_handles_size; ++i) {
int id;
@@ -439,6 +441,8 @@
ErrorCode rval;
+ if (!pcomm)
ALLOC_CHECK_ARRAY( part_handles, part_ids_size );
for (int i = 0; i < part_ids_size; ++i) {
EntityHandle handle;
@@ -1528,6 +1532,8 @@
// make exchange entity and processor list
ErrorCode rval;
+ if (!pcomm)
std::vector<unsigned int> exchange_procs;
std::vector< Range* > exchange_ents;
@@ -1612,6 +1618,8 @@
// need to update ParallelComm::update_shared_mesh to fix this
+ if (!pcomm)
ErrorCode rval = pcomm->update_shared_mesh();
CHKERR(rval,"update failed");
RETURN (iBase_SUCCESS);
@@ -1626,6 +1634,8 @@
int *err )
+ if (!pcomm)
DimensionPair types;
if (entity_topo != iMesh_ALL_TOPOLOGIES)
types.first = types.second = mb_topology_table[entity_topo];
@@ -1669,6 +1679,8 @@
std::vector<Tag> src_tags(1, itaps_cast<Tag>(source_tag));
