[MOAB-dev] r5691 - MOAB/trunk/src/moab/point_locater
rhl6856 at mcs.anl.gov
Mon Aug 13 11:49:48 CDT 2012
Author: rhl6856
Date: 2012-08-13 11:49:48 -0500 (Mon, 13 Aug 2012)
New Revision: 5691
Modified:
MOAB/trunk/src/moab/point_locater/bvh_tree.hpp
Log:
a bit more liberal use of tolerance in find alg. also added improved heuristic for choosing branch
Modified: MOAB/trunk/src/moab/point_locater/bvh_tree.hpp
--- MOAB/trunk/src/moab/point_locater/bvh_tree.hpp 2012-08-10 16:03:29 UTC (rev 5690)
+++ MOAB/trunk/src/moab/point_locater/bvh_tree.hpp 2012-08-13 16:49:48 UTC (rev 5691)
@@ -666,7 +666,9 @@
return 0;
- if( node.Lmax < node.Rmin){
+ //the extra tol here considers the case where
+ //0 < Rmin - Lmax < 2tol
+ if( (node.Lmax+tol) < (node.Rmin-tol)){
if( point[ node.dim] <= (node.Lmax + tol)){
return _find_point( point, node.child, tol);
}else if( point[ node.dim] >= (node.Rmin - tol)){
@@ -691,9 +693,11 @@
* sought point. This results in less overall traversal, and the correct
* cell is identified more quickly.
- const Entity_handle result = _find_point( point, node.child, tol);
+ bool dir = (point[ node.dim] - node.Rmin) <=
+ (node.Lmax - point[ node.dim]);
+ const Entity_handle result = _find_point( point, node.child+dir, tol);
if( result == 0 ){
- return _find_point( point, node.child+1, tol);
+ return _find_point( point, node.child+(1-dir), tol);
return result;
