[MOAB-dev] r5675 - in MOAB/trunk: src/moab/point_locater tools
rhl6856 at mcs.anl.gov rhl6856 at mcs.anl.gov
Fri Aug 3 14:45:00 CDT 2012
Author: rhl6856
Date: 2012-08-03 14:45:00 -0500 (Fri, 03 Aug 2012)
New Revision: 5675
Modified:
   MOAB/trunk/src/moab/point_locater/bvh_tree.hpp
   MOAB/trunk/tools/point_search.cpp
Log:
some typename warnings on older gcc
Modified: MOAB/trunk/src/moab/point_locater/bvh_tree.hpp
--- MOAB/trunk/src/moab/point_locater/bvh_tree.hpp	2012-08-03 19:18:36 UTC (rev 5674)
+++ MOAB/trunk/src/moab/point_locater/bvh_tree.hpp	2012-08-03 19:45:00 UTC (rev 5675)
@@ -81,7 +81,7 @@
 	class _Split_data {
 		public:
-		typedef typename ct::Box< double> Box;
+		typedef ct::Box< double> Box;
 		_Split_data(): dim( 0), nl( 0), nr( 0), split( 0.0),
 				Lmax( 0.0), Rmin( 0.0),bounding_box(),
 				left_box(), right_box(){}
Modified: MOAB/trunk/tools/point_search.cpp
--- MOAB/trunk/tools/point_search.cpp	2012-08-03 19:18:36 UTC (rev 5674)
+++ MOAB/trunk/tools/point_search.cpp	2012-08-03 19:45:00 UTC (rev 5675)
@@ -78,7 +78,7 @@
 }; // Parametrizer
 // default types.. whatevs.
-typedef typename moab::common_tree::Box< double> Bounding_box;
+typedef moab::common_tree::Box< double> Bounding_box;
 typedef std::vector< Bounding_box> Boxes;
 typedef moab::EntityHandle Element;
 typedef _Parametrizer< Element, std::vector< double> > Parametrizer;
@@ -186,12 +186,11 @@
 	std::size_t unfound_points = std::count( located_elements.begin(),
 						 located_elements.end(), 0);
 	typedef  ct::_Element_data< const Bounding_box, double > Element_data;
-	typedef typename std::tr1::unordered_map< Element,
-					  	  Element_data> Entity_map;
+	typedef std::tr1::unordered_map< Element,
+					 Element_data> Entity_map;
 	if( unfound_points > 0){
 		std::cout << "unlocated points: " <<  unfound_points
 		<< "/" << located_elements.size() << std::endl;
-		const std::size_t brute_search =
 		locator.bruteforce_locate_points( target_vertices,
 						  located_elements);
 	}else{
