[MOAB-dev] r5673 - MOAB/trunk/src/moab/point_locater
    rhl6856 at mcs.anl.gov
    Fri Aug  3 13:37:29 CDT 2012
Author: rhl6856
Date: 2012-08-03 13:37:29 -0500 (Fri, 03 Aug 2012)
New Revision: 5673
Added:
   MOAB/trunk/src/moab/point_locater/linear_hex_map.hpp
   MOAB/trunk/src/moab/point_locater/linear_tet_map.hpp
Log:
new natural parameter classes. still in development
Added: MOAB/trunk/src/moab/point_locater/linear_hex_map.hpp
--- MOAB/trunk/src/moab/point_locater/linear_hex_map.hpp	                        (rev 0)
+++ MOAB/trunk/src/moab/point_locater/linear_hex_map.hpp	2012-08-03 18:37:29 UTC (rev 5673)
@@ -0,0 +1,86 @@
+#ifndef MOAB_LINEAR_HEX_HPP
+#define MOAB_LINEAR_HEX_HPP
+namespace moab {
+namespace element_utility {
+namespace {
+template< typename Point, typename Points, typename Field>
+Field & evaluate_field( const Point & xi,
+       	      	   	const Point & field_values,
+       	      	     	Field & f){
+	//TODO: Field should default construct, F _f, use _f instead of f,
+	//then f = _f later..
+	for (unsigned i = 0; i < 8; ++i) {
+	  const double N_i = (1 + xi[0]*corner_xi[i][0])
+	                   * (1 + xi[1]*corner_xi[i][1])
+	                   * (1 + xi[2]*corner_xi[i][2]);
+	  f += N_i * f_vals[i];
+	f *= 0.125;
+	return f;
+} //anonymous namespace
+template< typename Point, typename Matrix>
+class Linear_hex_map {
+  private:
+	typedef Linear_hex_map< Point, Matrix> Self;
+  public:
+    //Constructor
+    template< typename Points>
+    Linear_hex_map( const Points & corners_ ) : corners( corners_) {}
+    //Copy constructor
+    Linear_hex_map( const Self & f ) : corners( f.corners) {}
+    //Initial Condition
+    Point& center_xi() const{ return Point(3, 0.0); }
+    Point& operator()( const Point & p) const{
+ 	Point x(3, 0.0);
+	return evaluate_field( xi, x, corners);
+    Point& operator()( const Point & p, const Point & f_vals) const{
+        double f=0.0;
+        return evaluate_field( xi, f_vals, f);
+    Matrix& jacobian( Point & p) const{
+	Matrix J;
