[MOAB-dev] r5661 - MOAB/trunk/src/moab/point_locater
    rhl6856 at mcs.anl.gov
    Fri Aug  3 13:37:19 CDT 2012
Author: rhl6856
Date: 2012-08-03 13:37:19 -0500 (Fri, 03 Aug 2012)
New Revision: 5661
Modified:
   MOAB/trunk/src/moab/point_locater/element_tree.hpp
Log:
debugging tree
Modified: MOAB/trunk/src/moab/point_locater/element_tree.hpp
--- MOAB/trunk/src/moab/point_locater/element_tree.hpp	2012-08-03 18:37:18 UTC (rev 5660)
+++ MOAB/trunk/src/moab/point_locater/element_tree.hpp	2012-08-03 18:37:19 UTC (rev 5661)
@@ -12,19 +12,36 @@
 #include <iostream>
 #include <map>
 #include <algorithm>
+#include <deque>
+#include <bitset>
 #ifndef ELEMENT_TREE_HPP
 #define ELEMENT_TREE_HPP
 namespace moab {
 //forward declarations
+template< typename T>
+void print_vector( const T & v){
+	typedef typename T::const_iterator Iterator;
+	std::cout << "[ ";
+	for(Iterator i = v.begin(); i != v.end(); ++i){
+		std::cout << *i;
+		if( i+1 != v.end()){
+			std::cout << ", ";
+	std::cout << " ]" << std::endl;
 struct Box{
 	typedef typename std::vector< double> Vector;
 	Box(): max(3,0.0), min(3,0.0){}
-	Box( const Vector & max_, const Vector & min_): max(max_), min(min_){}
 	Box( const Box & from): max( from.max), min( from.min){}
+	Box& operator=( const Box & from){
+		max = from.max;
+		min = from.min;
+		return *this;
 	Vector max;
 	Vector min;
 }; //Box
@@ -38,10 +55,13 @@
 template< typename Data>
 struct Split_comparator {
+  //max - min for correctness. it *might* be slightly slower
+  //but that is unlikely. compiler should optimize this.
   const std::size_t split_objective( const Data & a) const {
-  	return std::abs( a.left - a.right) + a.middle*a.middle;
