[MOAB-dev] r5659 - in MOAB/trunk: src/moab/point_locater tools
rhl6856 at mcs.anl.gov
Fri Aug 3 13:37:17 CDT 2012
Author: rhl6856
Date: 2012-08-03 13:37:17 -0500 (Fri, 03 Aug 2012)
New Revision: 5659
Modified:
MOAB/trunk/src/moab/point_locater/element_tree.hpp
MOAB/trunk/tools/point_search.cpp
Log:
bounding boxes
Modified: MOAB/trunk/src/moab/point_locater/element_tree.hpp
--- MOAB/trunk/src/moab/point_locater/element_tree.hpp 2012-08-03 18:37:16 UTC (rev 5658)
+++ MOAB/trunk/src/moab/point_locater/element_tree.hpp 2012-08-03 18:37:17 UTC (rev 5659)
@@ -19,6 +19,20 @@
namespace moab {
//forward declarations
+struct Box{
+ typedef typename std::vector< double> Vector;
+ Box(): max(3,0.0), min(3,0.0){}
+ Box( const Vector & max_, const Vector & min_): max(max_), min(min_){}
+ Box( const Box & from): max( from.max), min( from.min){}
+ Vector max;
+ Vector min;
+}; //Box
template< typename _Entity_handles,
typename _Boxes,
typename _Moab> class Element_tree;
@@ -88,7 +102,7 @@
bool operator()( const Iterator a, const Iterator b){
return (*a).first < (*b).first;
-}; // Element_compae
+}; // Element_compare
@@ -113,8 +127,8 @@
_Boxes,
_Moab> Self;
typedef typename _element_tree::Node< Entity_handles> Node;
- typedef typename Boxes::value_type Box;
- typedef typename std::pair< Box, std::size_t> Data;
+ typedef typename std::pair< typename Boxes::value_type,
+ std::size_t> Data;
typedef typename Entity_handles::value_type Entity_handle;
//TODO: we really want an unordered map here..
typedef typename std::map< Entity_handle, Data> Entity_map;
@@ -135,7 +149,7 @@
elements[ ++index] = i;
//We only build nonempty trees
- if( entity_handles_.size()){
+ if( elements.size()){
