[MOAB-dev] r5657 - MOAB/trunk/src/moab/point_locater
rhl6856 at mcs.anl.gov
Fri Aug 3 13:37:15 CDT 2012
Author: rhl6856
Date: 2012-08-03 13:37:15 -0500 (Fri, 03 Aug 2012)
New Revision: 5657
Modified:
MOAB/trunk/src/moab/point_locater/point_locater.hpp
Log:
level 2
Modified: MOAB/trunk/src/moab/point_locater/point_locater.hpp
--- MOAB/trunk/src/moab/point_locater/point_locater.hpp 2012-08-03 18:37:14 UTC (rev 5656)
+++ MOAB/trunk/src/moab/point_locater/point_locater.hpp 2012-08-03 18:37:15 UTC (rev 5657)
@@ -18,6 +18,8 @@
public:
typedef _Tree Tree;
typedef typename Elements::value_type Element;
+ //arbitrary type for now.. A box should be a small struct, boxes a
+ //Vector of them, or a set?
typedef std::vector< std::vector< std::size_t> > Boxes;
//temporary error code
typedef typename std::size_t Error;
@@ -37,21 +39,31 @@
source_elements( _source_elements),
comm( _comm), boxes(),
iterations( _iterations){}
+//private functionality
+private:
+template< typename Points, typename Bitmask>
+void local_point_search( const Points & query_points, Bitmask & located_points,
+ Elements & result,
+ const double rel_eps, const double abs_eps){}
+//public functionality
+public:
template< typename Points>
Error locate_points( Points & query_points, Elements & result,
+ //bitmask for located points
+ std::vector< bool> located_points( query_points.size(), 0);
+ local_point_search( query_points, located_points,
+ result, rel_eps, abs_eps);
+ resolve_boxes( query_points, located_points, rel_eps, abs_eps);
+ //scatter-gather
+ //TODO: probably too good to be true..
+ //send back to target
return 0;
-template< typename Points>
-Error locate_points( Points & query_points,
- const double rel_eps = 0.0,
- const double abs_eps = 0.0){
- Elements result;
- return locate_points( query_points, result, rel_eps, abs_eps);
//public accessor methods
