[MOAB-dev] r5654 - MOAB/trunk/src/moab/point_locater
rhl6856 at mcs.anl.gov
Fri Aug 3 13:37:13 CDT 2012
Author: rhl6856
Date: 2012-08-03 13:37:13 -0500 (Fri, 03 Aug 2012)
New Revision: 5654
Added:
MOAB/trunk/src/moab/point_locater/initialize_tree.hpp
MOAB/trunk/src/moab/point_locater/nat_param.hpp
Modified:
MOAB/trunk/src/moab/point_locater/point_locater.hpp
Log:
point locater nonsense
Added: MOAB/trunk/src/moab/point_locater/initialize_tree.hpp
--- MOAB/trunk/src/moab/point_locater/initialize_tree.hpp (rev 0)
+++ MOAB/trunk/src/moab/point_locater/initialize_tree.hpp 2012-08-03 18:37:13 UTC (rev 5654)
@@ -0,0 +1,71 @@
+#ifndef INIT_TREE_HPP
+#define INIT_TREE_HPP
+//TODO: refactor out to AdaptiveKDTree
+ErrorCode initialize_tree(){
+ Range local_ents;
+ typename Tree::Settings settings;
+ settings.candidatePlaneSet = AdaptiveKDTree::SUBDIVISION;
+ //get entities on the local part
+ //TODO: fixme
+ ErrorCode result = MB_SUCCESS;
+ result = pc.get_part_entities( local_ents, 3);
+ else local_ents = range;
+ if (MB_SUCCESS != result || local_ents.empty()) {
+ std::cout << "Problems getting source entities"
+ << std::endl;
+ return result;
+ // build the tree for local processor
+ for (int i = 0; i < num_iterations; i++) {
+ tree = Tree( &impl);
+ result = tree.build_tree( local_ents, local_root, &settings);
+ if (MB_SUCCESS != result) {
+ std::cout << "Problems building tree";
+ if (num_iterations != i) {
+ settings.maxEntPerLeaf *= 2;
+ std::cout << "; increasing elements/leaf to "
+ << settings.maxEntPerLeaf << std::endl;;
+ else {
+ std::cout << "; exiting" << std::endl;
+ return result;
+ else
+ break; // get out of tree building
+ boxes.resize(6*pc.proc_config().proc_size());
+ unsigned int rank = (pc ? pc.proc_config().proc_rank() : 0);
+ result = tree.get_tree_box( local_root,
+ &boxes[6*rank],
+ &boxes[6*rank+3]);
