[MOAB-dev] r5638 - MOAB/trunk/src/io
xbxu at mcs.anl.gov
xbxu at mcs.anl.gov
Wed Jul 25 14:42:36 CDT 2012
Author: xbxu
Date: 2012-07-25 14:42:36 -0500 (Wed, 25 Jul 2012)
New Revision: 5638
Modified:
MOAB/trunk/src/io/ReadNC.cpp
Log:
fix the serial build
Modified: MOAB/trunk/src/io/ReadNC.cpp
--- MOAB/trunk/src/io/ReadNC.cpp 2012-07-25 18:44:37 UTC (rev 5637)
+++ MOAB/trunk/src/io/ReadNC.cpp 2012-07-25 19:42:36 UTC (rev 5638)
@@ -3002,14 +3002,21 @@
std::string tag_name = "COORDS";
- void * val = &coords[0];
- int val_len = coords.size();
Tag tagh = 0;
rval = mbImpl->tag_get_handle(tag_name.c_str(), 3, MB_TYPE_DOUBLE, tagh, MB_TAG_DENSE|MB_TAG_CREAT);
ERRORR(rval, "Trouble creating COORDS tag.");
- rval = mbImpl->tag_set_by_ptr(tagh, &file_set, 1, &val, &val_len);
- ERRORR(rval, "Trouble setting data for COORDS tag.");
+ void *data;
+ int count;
+#ifdef USE_MPI
+ rval = mbImpl->tag_iterate(tagh, ents_owned.begin(), ents_owned.end(), count, data);
+#else
+ rval = mbImpl->tag_iterate(tagh, ents.begin(), ents.end(), count, data);
+#endif
+ ERRORR(rval, "Failed to get COORDS tag iterator.");
+ assert(count == (int)numOwnedEnts);
+ double* quad_data = (double*)data;
+ std::copy(coords.begin(), coords.end(), quad_data);
return MB_SUCCESS;
