[MOAB-dev] r5629 - in MOAB/trunk: doc src/io
hayes6 at mcs.anl.gov
Tue Jul 10 14:09:14 CDT 2012
Author: hayes6
Date: 2012-07-10 14:09:14 -0500 (Tue, 10 Jul 2012)
New Revision: 5629
Modified:
MOAB/trunk/doc/metadata_info.doc
MOAB/trunk/src/io/ReadNC.cpp
MOAB/trunk/src/io/ReadNC.hpp
Log:
updated HOMME NC data reader for unstructured meshes, support for parallel reading with element based partition
Modified: MOAB/trunk/doc/metadata_info.doc
(Binary files differ)
Modified: MOAB/trunk/src/io/ReadNC.cpp
--- MOAB/trunk/src/io/ReadNC.cpp 2012-07-09 20:29:06 UTC (rev 5628)
+++ MOAB/trunk/src/io/ReadNC.cpp 2012-07-10 19:09:14 UTC (rev 5629)
@@ -125,6 +125,7 @@
// Open the file
dbgOut.tprintf(1, "Opening file %s\n", file_name);
+ fileName = std::string(file_name);
int success;
#ifdef PNETCDF_FILE
@@ -229,7 +230,7 @@
else if (!nomesh) {
if (ucdMesh)
- rval = create_ucd_verts_hexes(opts, tmp_set, quads);
+ rval = create_ucd_verts_quads(opts, tmp_set, quads);
else
rval = create_verts_quads(scdi, tmp_set, quads);
ERRORR(rval, "Trouble creating vertices.");
@@ -245,17 +246,29 @@
rval = read_variables(tmp_set, dimNames, tstep_nums);
if (MB_FAILURE == rval) return rval;
#ifdef USE_MPI
// create partition set, and populate with elements
if (isParallel) {
EntityHandle partn_set;
rval = mbImpl->create_meshset(MESHSET_SET, partn_set);
ERRORR(rval, "Trouble creating partition set.");
+ Range verts;
+ mbImpl->get_entities_by_type(0, MBVERTEX, verts);
+ mbImpl->add_entities(partn_set,quads);
+ mbImpl->add_entities(partn_set,verts);
myPcomm->partition_sets().insert(partn_set);
rval = mbImpl->add_entities(partn_set, quads);
- ERRORR(rval, "Couldn't add new hexes to partition set.");
+ ERRORR(rval, "Couldn't add new quads to partition set.");
+#ifndef NDEBUG
+ rval = myPcomm->resolve_shared_ents(0,-1,-1);
+ ERRORR(rval, "Trouble resolving shared entities");
+ //TODO print which procs own which verts, check global number of verts
