[MOAB-dev] r5620 - in MOAB/branches/NCparperiodic: src src/io src/moab test/parallel
tautges at mcs.anl.gov
Fri Jun 29 19:34:27 CDT 2012
Author: tautges
Date: 2012-06-29 19:34:27 -0500 (Fri, 29 Jun 2012)
New Revision: 5620
Modified:
MOAB/branches/NCparperiodic/src/ScdInterface.cpp
MOAB/branches/NCparperiodic/src/io/ReadNC.cpp
MOAB/branches/NCparperiodic/src/moab/ScdInterface.hpp
MOAB/branches/NCparperiodic/test/parallel/Makefile.am
Log:
Lots of bug fixes, scdpart now works (on 2 procs at least).
Modified: MOAB/branches/NCparperiodic/src/ScdInterface.cpp
--- MOAB/branches/NCparperiodic/src/ScdInterface.cpp 2012-06-29 21:39:36 UTC (rev 5619)
+++ MOAB/branches/NCparperiodic/src/ScdInterface.cpp 2012-06-30 00:34:27 UTC (rev 5620)
@@ -676,12 +676,14 @@
pto = -1;
across_bdy[0] = across_bdy[1] = 0;
- int ldims[6], pijk[3], lperiodic[3];
+ int ldims[6], pijk[3], lperiodic[2];
ErrorCode rval = compute_partition_alljkbal(np, pfrom, gdims, gperiodic,
ldims, lperiodic, pijk);
if (MB_SUCCESS != rval) return rval;
assert(pijk[1] * pijk[2] == np);
pto = -1;
+ bool bot_j = pfrom < pijk[2],
+ top_j = pfrom > np - pijk[2];
if ((1 == pijk[2] && dijk[2]) || // 1d in j means no neighbors with dk != 0
(!(pfrom%pijk[2]) && -1 == dijk[2]) || // at -k bdy
(pfrom%pijk[2] == pijk[2]-1 && 1 == dijk[2]) || // at +k bdy
@@ -699,7 +701,7 @@
int dj = (gdims[4] - gdims[1]) / pijk[1], extra = (gdims[4] - gdims[1]) % pijk[1];
if (-1 == dijk[1]) {
facedims[4] = facedims[1];
- if (pfrom < pijk[2]) {
+ if (bot_j) {
// going across periodic lower bdy in j
rdims[4] = gdims[4];
across_bdy[1] = -1;
@@ -713,7 +715,7 @@
else {
if (pfrom > np-pijk[2]) facedims[4] = gdims[1];
facedims[1] = facedims[4];
- if (pfrom > np - pijk[2]) {
+ if (top_j) {
// going across periodic upper bdy in j
rdims[1] = gdims[1];
across_bdy[1] = 1;
@@ -742,22 +744,21 @@
- assert(-1 == pto ||
- (rdims[0] >= gdims[0] && rdims[3] <= gdims[3] &&
- rdims[1] >= gdims[1] && rdims[4] <= gdims[4] &&
- rdims[2] >= gdims[2] && rdims[5] <= gdims[5] &&
- (facedims[0] >= rdims[0] || (gperiodic[0] && rdims[3] == gdims[3] && facedims[0] == gdims[0])) &&
- facedims[3] <= rdims[3] &&
- (facedims[1] >= rdims[1] || (gperiodic[1] && rdims[4] == gdims[4] && facedims[1] == gdims[1])) &&
- facedims[4] <= rdims[4] &&
- facedims[2] >= rdims[2] &&
