[MOAB-dev] r5572 - MOAB/branches/nc_to_2.5d/src/io
xbxu at mcs.anl.gov
xbxu at mcs.anl.gov
Wed Jun 13 09:17:45 CDT 2012
Author: xbxu
Date: 2012-06-13 09:17:37 -0500 (Wed, 13 Jun 2012)
New Revision: 5572
Modified:
MOAB/branches/nc_to_2.5d/src/io/ReadNC.cpp
MOAB/branches/nc_to_2.5d/src/io/ReadNC.hpp
Log:
minor bug fixes
Modified: MOAB/branches/nc_to_2.5d/src/io/ReadNC.cpp
--- MOAB/branches/nc_to_2.5d/src/io/ReadNC.cpp 2012-06-12 21:06:16 UTC (rev 5571)
+++ MOAB/branches/nc_to_2.5d/src/io/ReadNC.cpp 2012-06-13 14:17:37 UTC (rev 5572)
@@ -223,7 +223,7 @@
// Create mesh vertex/quads sequences
Range quads;
if (nomesh && !novars) {
- rval = check_verts_hexes(tmp_set);
+ rval = check_verts_quads(tmp_set);
ERRORR(rval, "Mesh characteristics didn't match from last read.\n");
else if (!nomesh) {
@@ -359,7 +359,7 @@
return MB_SUCCESS;
-ErrorCode ReadNC::check_verts_hexes(EntityHandle file_set)
+ErrorCode ReadNC::check_verts_quads(EntityHandle file_set)
// check parameters on this read against what was on the mesh from last read
// get the number of vertices
@@ -752,8 +752,8 @@
// get quads in set
Range quads;
rval = mbImpl->get_entities_by_dimension(file_set, 2, quads);
- ERRORR(rval, "Trouble getting vertices in set.");
- assert("Should only have a single vertex subrange, since they were read in one shot" &&
+ ERRORR(rval, "Trouble getting quads in set.");
+ assert("Should only have a single quad subrange, since they were read in one shot" &&
quads.psize() == 1);
//quads_handles.resize(quads.size());
//std::copy(quads.begin(), quads.end(), quads_handles.begin());
@@ -1636,6 +1636,8 @@
case NC_BYTE:
case NC_CHAR:
case NC_DOUBLE:
+ data_type = MB_TYPE_DOUBLE;
+ break;
case NC_FLOAT:
break;
@@ -1972,6 +1974,8 @@
case NC_BYTE:
case NC_CHAR:
case NC_DOUBLE:
+ break;
case NC_FLOAT:
break;
