[MOAB-dev] make check on 4.5 branch with gcc-4.1.2
Tim Tautges tautges at mcs.anl.gov
Wed May 30 13:03:04 CDT 2012
Not the fortran examples.  That only became possible with gcc4.3 and newer.
- tim
On 05/30/2012 12:44 PM, Mark Miller wrote:
> Hi Tim,
> Should I expect a 'make check' in the itaps dir for MAOB Version4.5
> branch to compile correctly for gcc-4.1.2?
> I am seeing...
> SET=tr1/unordered_set  -O2 -fcray-pointer -c -o ScdMeshF90.o ScdMeshF90.F90
>   In file ScdMeshF90.F90:58
> call iMesh_createStructuredMesh(%VAL(mesh), local_dims, global_dims, %VAL(0),%V
>                                 1
> Error: Syntax error in argument list at (1)
>   In file ScdMeshF90.F90:61
> call iMesh_getRootSet(%VAL(mesh), root_set, ier); if (0 .ne. ier) call exit(1);
>                       1
>   In file ScdMeshF90.F90:63
> call iMesh_getGeometricDimension(%VAL(mesh), geom_dim, ier); if (0 .ne. ier) ca
>                                  1
>   In file ScdMeshF90.F90:65
> call iMesh_getNumOfType(%VAL(mesh), %VAL(root_set), %VAL(iBase_FACE), num_regio
>                         1
>   In file ScdMeshF90.F90:67
> call iMesh_getNumOfType(%VAL(mesh), %VAL(root_set), %VAL(iBase_VERTEX), num_ver
>                         1
>   In file ScdMeshF90.F90:69
> call iMesh_initEntArrIter(%VAL(mesh), %VAL(root_set), %VAL(iBase_FACE), %VAL(iM
>                           1
>   In file ScdMeshF90.F90:72
> call iMesh_createTagWithOptions(%VAL(mesh), "XM1", "moab:TAG_STORAGE_TYPE=DENSE
>                                 1
>   In file ScdMeshF90.F90:75
> call iMesh_tagIterate(%VAL(mesh), %VAL(tagh), %VAL(iter), rpxm1, count, ier); i
>                       1
> make[3]: *** [ScdMeshF90.o] Error 1
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
