[MOAB-dev] r5515 - MOAB/trunk/src/io
xbxu at mcs.anl.gov xbxu at mcs.anl.gov
Thu May 10 15:43:41 CDT 2012
Author: xbxu
Date: 2012-05-10 15:43:41 -0500 (Thu, 10 May 2012)
New Revision: 5515
Modified:
   MOAB/trunk/src/io/ReadNC.cpp
Log:
assume i direction is periordic for now; will add the logic to determine wether it is later
Modified: MOAB/trunk/src/io/ReadNC.cpp
--- MOAB/trunk/src/io/ReadNC.cpp	2012-05-10 17:34:33 UTC (rev 5514)
+++ MOAB/trunk/src/io/ReadNC.cpp	2012-05-10 20:43:41 UTC (rev 5515)
@@ -330,7 +330,7 @@
   ScdBox *scd_box;
   ErrorCode rval = scdi->construct_box(HomCoord(lDims[0], lDims[1], (-1 != lDims[2] ? lDims[2] : 0), 1),
                                        HomCoord(lDims[3], lDims[4], (-1 != lDims[5] ? lDims[5] : 0), 1),
-                                       NULL, 0, scd_box);
+                                       NULL, 0, scd_box, true);
   ERRORR(rval, "Trouble creating scd vertex sequence.");
     // set the global box parameters
