[MOAB-dev] r5510 - MOAB/trunk/tools/mbcoupler
iulian at mcs.anl.gov
Sun Apr 29 09:50:49 CDT 2012
Author: iulian
Date: 2012-04-29 09:50:48 -0500 (Sun, 29 Apr 2012)
New Revision: 5510
Modified:
MOAB/trunk/tools/mbcoupler/ElemUtil.cpp
Log:
correct integration over spectral element
w are not the weights, J's are the weights
got tricked by notations :(
Modified: MOAB/trunk/tools/mbcoupler/ElemUtil.cpp
--- MOAB/trunk/tools/mbcoupler/ElemUtil.cpp 2012-04-28 16:23:46 UTC (rev 5509)
+++ MOAB/trunk/tools/mbcoupler/ElemUtil.cpp 2012-04-29 14:50:48 UTC (rev 5510)
@@ -744,20 +744,24 @@
double xi[3];
//triple loop; the most inner loop is in r direction, then s, then t
double integral = 0.;
+ //double volume = 0;
int index=0; // used fr the inner loop
for (int k=0; k<_n; k++ )
xi[2]=_ld[2].z[k];
- double wk= _ld[2].w[k];
+ //double wk= _ld[2].w[k];
for (int j=0; j<_n; j++)
xi[1]=_ld[1].z[j];
- double wj= _ld[1].w[j];
+ //double wj= _ld[1].w[j];
for (int i=0; i<_n; i++)
xi[0]=_ld[0].z[i];
- double wi= _ld[0].w[i];
+ //double wi= _ld[0].w[i];
opt_vol_set_intp_3(&_data,xi);
+ double wk= _ld[2].J[k];
+ double wj= _ld[1].J[j];
+ double wi= _ld[0].J[i];
Matrix3 J(0.);
// it is organized differently
J(0,0) = _data.jac[0]; // dx/dr
@@ -769,11 +773,13 @@
J(2,0) = _data.jac[6]; // dz/dr
J(2,1) = _data.jac[7]; // dz/ds
J(2,2) = _data.jac[8]; // dz/dt
- double bm = wk*wj*wi*J.determinant();
+ double bm = wk*wj*wi* J.determinant();
integral+= bm*field_vertex_values[index++];
+ //volume +=bm;
+ //std::cout << "volume: " << volume << "\n";
return integral;
