[MOAB-dev] r5508 - MOAB/trunk/tools/mbcoupler
iulian at mcs.anl.gov
Fri Apr 27 23:02:25 CDT 2012
Author: iulian
Date: 2012-04-27 23:02:25 -0500 (Fri, 27 Apr 2012)
New Revision: 5508
Modified:
MOAB/trunk/tools/mbcoupler/ElemUtil.cpp
MOAB/trunk/tools/mbcoupler/ElementTest.cpp
MOAB/trunk/tools/mbcoupler/extrafindpt.h
MOAB/trunk/tools/mbcoupler/findpt.c
Log:
add integration over spectral element and jacobian at a point.
need to compare to NEK5000 computation and need to add an example
of normalization
Modified: MOAB/trunk/tools/mbcoupler/ElemUtil.cpp
--- MOAB/trunk/tools/mbcoupler/ElemUtil.cpp 2012-04-28 00:22:03 UTC (rev 5507)
+++ MOAB/trunk/tools/mbcoupler/ElemUtil.cpp 2012-04-28 04:02:25 UTC (rev 5508)
@@ -699,7 +699,25 @@
Matrix3 SpectralHex::jacobian(const CartVect& xi) const
- return Matrix3(0.);
+ real x_i[3];
+ xi.get(x_i);
+ // set the positions of GL nodes, before evaluations
+ _data.elx[0]=_xyz[0];
+ _data.elx[1]=_xyz[1];
+ _data.elx[2]=_xyz[2];
+ opt_vol_set_intp_3(&_data,x_i);
+ Matrix3 J(0.);
+ // it is organized differently
+ J(0,0) = _data.jac[0]; // dx/dr
+ J(0,1) = _data.jac[1]; // dx/ds
+ J(0,2) = _data.jac[2]; // dx/dt
+ J(1,0) = _data.jac[3]; // dy/dr
+ J(1,1) = _data.jac[4]; // dy/ds
+ J(1,2) = _data.jac[5]; // dy/dt
+ J(2,0) = _data.jac[6]; // dz/dr
+ J(2,1) = _data.jac[7]; // dz/ds
+ J(2,2) = _data.jac[8]; // dz/dt
+ return J;
double SpectralHex::evaluate_scalar_field(const CartVect& xi, const double *field) const
@@ -718,7 +736,45 @@
double SpectralHex::integrate_scalar_field(const double *field_vertex_values) const
- return 0;
+ // set the position of GL points
+ double xi[3];
+ //triple loop; the most inner loop is in r direction, then s, then t
+ double integral = 0.;
+ int index=0; // used fr the inner loop
+ for (int k=0; k<_n; k++ )
+ xi[2]=_ld[2].z[k];
+ double wk= _ld[2].w[k];
+ for (int j=0; j<_n; j++)
