[MOAB-dev] r5500 - MOAB/trunk/tools/mbcoupler
    iulian at mcs.anl.gov
    Thu Apr 26 06:51:01 CDT 2012
Author: iulian
Date: 2012-04-26 06:51:01 -0500 (Thu, 26 Apr 2012)
New Revision: 5500
Modified:
   MOAB/trunk/tools/mbcoupler/Coupler.cpp
Log:
spectral target flag and some formatting
Modified: MOAB/trunk/tools/mbcoupler/Coupler.cpp
--- MOAB/trunk/tools/mbcoupler/Coupler.cpp	2012-04-25 23:37:02 UTC (rev 5499)
+++ MOAB/trunk/tools/mbcoupler/Coupler.cpp	2012-04-26 11:51:01 UTC (rev 5500)
@@ -191,9 +191,9 @@
     // repeat for target sets
     spectral_sets.empty();
-    // now initialize a source spectral element !
+    // now initialize a target spectral element !
     _spectralTarget = new moab::Element::SpectralHex(sem_dims[0]);
-    specSou = true;
+    specTar = true;
   _ntot = sem_dims[0]*sem_dims[1]*sem_dims[2];
@@ -585,7 +585,7 @@
   result = mbImpl->get_entities_by_dimension(treeiter.handle(), 3, range_leaf, false);
   if(result != MB_SUCCESS) std::cout << "Problem getting leaf in a range" << std::endl;
-    // loop over the range_leaf
+  // loop over the range_leaf
   for(Range::iterator iter = range_leaf.begin(); iter != range_leaf.end(); iter++)
     //test to find out in which entity the point is
@@ -620,7 +620,6 @@
       spcHex->set_gl_points((double*)xval, (double*)yval, (double*)zval);
       try{
         tmp_nat_coords =spcHex->ievaluate(CartVect(xyz));
       catch (Element::Map::EvaluationError) {
@@ -629,8 +628,6 @@
         continue; // it is possible that the point is outside, so it will not converge
     else
@@ -648,7 +645,6 @@
         return result;
       if (etype == MBHEX) {
         Element::LinearHex hexmap(coords_vert);
         try {
@@ -689,69 +685,70 @@
