[MOAB-dev] r5495 - MOAB/trunk/tools/mbcoupler
    iulian at mcs.anl.gov
    Tue Apr 24 17:02:08 CDT 2012
Author: iulian
Date: 2012-04-24 17:02:08 -0500 (Tue, 24 Apr 2012)
New Revision: 5495
Modified:
   MOAB/trunk/tools/mbcoupler/Coupler.cpp
   MOAB/trunk/tools/mbcoupler/ElemUtil.cpp
Log:
small changes to make it a little faster
spectral element is not done yet
Modified: MOAB/trunk/tools/mbcoupler/Coupler.cpp
--- MOAB/trunk/tools/mbcoupler/Coupler.cpp	2012-04-24 16:50:03 UTC (rev 5494)
+++ MOAB/trunk/tools/mbcoupler/Coupler.cpp	2012-04-24 22:02:08 UTC (rev 5495)
@@ -89,6 +89,8 @@
         return result;
+    else
+      break; // get out of tree building
     // get the bounding box for local tree
@@ -475,7 +477,7 @@
   if(MB_ENTITY_NOT_FOUND==result) //point is outside of myTree's bounding box
     return MB_SUCCESS;
   if (MB_SUCCESS != result) {
-    std::cout << "Problems getting leaf " << std::endl;
+    std::cout << "Problems getting leaf \n";
     return result;
@@ -496,16 +498,11 @@
       //get coordinates of the vertices
     std::vector<CartVect> coords_vert(num_connect);
-    std::vector<double> coords(3*num_connect);
-    result = mbImpl->get_coords(connect, num_connect, &coords[0]);
-    for(int j = 0; j < num_connect; j++)
-      coords_vert[j][0] = coords[3*j];
-      coords_vert[j][1] = coords[3*j+1];
-      coords_vert[j][2] = coords[3*j+2];
+    result = mbImpl->get_coords(connect, num_connect, &(coords_vert[0][0]));
+    if (MB_SUCCESS != result) {
+      std::cout << "Problems getting coordinates of vertices\n";
+      return result;
       //test to find out in which entity the point is
       //get the EntityType and create the appropriate Element::Map subtype
     EntityType etype = mbImpl->type_from_handle(*iter);
@@ -572,12 +569,12 @@
   int num_connect;
   ErrorCode result = mbImpl->get_connectivity(elem, connect, num_connect);
-    free(elemMap);
+    delete elemMap;
     return result;
